M_R_205
Oil Filer/breather When Using Carbs
M_R_205
iv done a search and come up with nothing definative :)
am i coprrect in thinking when i fit R1 carbs (or any other sort) all you have to do is fit a breather filter thingy to the filler cap? its the genral idea i get when looking at the search results,
also if i replace all the crap rubber filler breather pipes with alloy ones, this shouldnt cause any problems should it?
ohh aye its an mi16 ally block
cheers
Paul
Edited by M_R_205
Richie-Van-GTi
you need to fit a catch tank with a breather filter. Just sticking a filter on will soon clog up with oil and be useless. Alloy pipes wont do it any harm either, plus they are easier to clean out if needed later on :)
M_R_205
you need to fit a catch tank with a breather filter. Just sticking a filter on will soon clog up with oil and be useless. Alloy pipes wont do it any harm either, plus they are easier to clean out if needed later on :D
my mate has a spare catch tank i could use,, how would i conect one up?? would the filler neck not act like a catch tank?
