mos 1 Posted February 14, 2007 hi, i have tried searching but no joy i know that p/s with 45s can be done as i had this fitted to a 205 i had about 5 years ago. but how, one of my mates is fitting it to his 8v and its fouling the alternator but i cant for the life of me remember how the clearance required etc was achieve i know you can use the electric pump and i have this syetm on my own 8v but the feel is not as nice as the proper pump and belt set up i know some of you guys have both carbs and p/s like i used to have but how have you done it help please!!! thanks mark Share this post Link to post Share on other sites
mos 1 Posted March 30, 2007 well i have maanged to suss this with a lot of grinding of the alloy bracket that mounts the alternator and pump to the engine and also fabricating a new metal bracket to mount the p/s pump slightly lower. i also then used a different adjuster bracket (not sure what is off, its one i had lying around) to gain some extra adjustment on the belt and used a belt to suit. so it can be done, but its a bit of a pain, lots of trial and error and very time consuming although if i were to do it again i bet i would manage it in a quarter of the time thanks mark Share this post Link to post Share on other sites
boldy205 75 Posted March 30, 2007 out of intrest, what have the carbs got to do with PAS? in probabaly missing somthing?! Share this post Link to post Share on other sites
28CRAIG 2 Posted March 31, 2007 The alternater sits higher up above the pump so would catch on the carbs. Share this post Link to post Share on other sites
