clifton
Piper 285 Cam
clifton
i am after an uprated cam and i have been looking at the piper 285 cams but it says not recommended for use with standard injection, but if i run it with standard injection would it do any harm? and if it would what could i do to make t suitable to use
Ahl
It probably won't do any harm, it just won't idle very well at all! (and these engines idle badly as standard).
From my understanding, the head is also quite restrictive so in order to get a decent gain (or just a better starting point anyway) you'd want to have the ports flowed properly, as well as having it skimmed in order to raise compression.
In addition to this, its likely the standard management won't be able to supply the correct fuelling for the cam.
So do all that...or fit an mi16. :blink::P
vtr_driver
I seem to remember reading an article written by the head honcho of Puma Racing saying most cams for the 8v GTI don't actually work and the way to release power is by doing headwork.
I don't know how true this is. It may be my dodgy memory playing tricks on me
clifton
the head i have has been port and polished and i think it has been skimmed....is it not worth doing then or should i go for it?
and i would get an mi16 but i wouldnt be able to get insured on it...and its seeming harder and harder now to get a decent condition engine
boombang
I found insurance was as cheap if not cheaper with an Mi in a 205, as have many others!
clifton
im only 17 though and my insurance is already £2500 ha but i doubt it would be cheaper for me at that age
GLPoomobile
If you go through companies such as HIC or Adrian Flux they tend to insure the vehicle based on the group of the donor vehicle. A 1.9 gti is group 15 (IIRC) which is the same as a 405 Mi16 (again, IIRC). Hence many members have found it does not change their insurance. Some have even ended up saving on the insurance as I think the Cit BX 16v is a group lower!
Anyway, the point is you are going to get an increase in your insurance anyway if you start tuning your engine, and I'm lead to believe that insurers will often charge more for a tuned engine than a standard engine transplanted and of similar power.
vtr_driver
Thats brilliant!!
Hmm I have no experence with Insuring an MI but at 17 I can't imagine it being cheap.
