Guest ajsik
Warm Engine Problem
Guest ajsik
when engine is cold, starts fine idle fine at 1400 rpm. Also it goes smooth in low, mid even high rpm. No revs drops below 1000rpm. no missfiring
But once is warmed
- it starts to huge missfiring to the exhaust
- almost no stable idle revs - engine dies with the huge missfire into to the intake because of very low rpm ...
- even I press the throtle pedal, the engine has a big trouble to goes to mid revs (still missfiring), in high revs is noisy...
- it is almost imposiblle to start the engine, you have to assist it by throtle pedal and it after a big troubles starts but missfiring ...
no "K" light
O2 sensor is brand new and good
there is a konic filter (JR)
AFM itself (wirring may be not) is ok, i measured it before and it gives me good voltage values in all rev range.
could any one help ?
Edited by ajsik
sounds like it could be the ECU coolant temp sensor to me.
Guest ajsik
the one that is near to SAD, at the back side of head?
it is DKZ XU9JAZ engine
Edited by ajsik
yes, thats the one, a blue two pin type.
yup, thats the one! same symptoms as i had a few weeks ago.
bosch part no - 0280 130 026 Peugeot part No 0242 46
Guest ajsik
thanks guys, I will try it at the afternoon. I am praying to be that coolant sensor ;-). Cuz I need to drive about 150miles to home from college.
Guest ajsik
btw, if anyone has still some other idea what it could be, pls write here, thank you
Guest ajsik
I've changed the coolant temp sensor and finally it goes nice and smooth cold or warm , i had no more time to take a longer test drive but it seems to be allright. Tommorow I am going home so I will probe it on motorway and in the city.
Many thanks for quick and useful help :-)
Edited by ajsik
