johnnyboy666
Hub Adapters And Larger Offset?
johnnyboy666
right, i'm planning on fitting a set of ats cups to my xs (youve probably seen them on golfs or polos) http://cgi.ebay.co.uk/ATS-Cup-7x15-ET20-VW...VQQcmdZViewItem
just to show you what they look like, i think they would look amazing on a 205 giving it a real euro look and as far as i'm aware its never been done before, the only problem is they only make them in pcd 4x100 so i need to use hub adapters which cost me an arm and a leg, and theyre 25mm thick also the wheels only come in offsets of 20 or 28 thus giving me (i think) an offset of either 45 or 53 which is a lot larger than the intended offset (23? or so) so what i want to know is how the offset will affect the handling and drivability of the car?
also they come in 7inch wide or 8 inch wide, i will have wide arches on the car by the time i get these so im just wondering which would be best?
thanks
john
Ahl
I think you might be struggling to fit these.
The offset you want is ET19 (which I believe is the same for most base models and the 1.9 GTI.)
The offset and hub adapters work the other way round, so fitting the 25mm adapter to the ET28 wheel will bring it to ET3. This means the centre line of the wheel will be sticking out by 16mm more than the original wheels.
They will probably rub the standard arches quite seriously at that, and it won't do the handling any good at all. (Even if you only fit the 7" rims, which are still pretty wide. 8" is just silly for the car and ruin the handling even further.)
Unfortunately it seems like a lot of work and expense, just so you can have the ATS wheels on your car. Perhaps you could try contacting ATS directly to see if they would make a set of the ET20 wheels in the correct PCD?
If you decide to have it as a 'show car' (and completely disregard the handling) then theres nothing to stop you getting the hub adapters, wide wheels and wide arches. :)
johnnyboy666
some good points there thanks, as for contacting ats to make a special set for me i think thats a little to much effort and would be far to expensive plus they would most likely say no.
does anybody who has or has driven a dimma have anything to note about the handling as they must have some pretty substantial spacers or extremely wide wheels ( i believe t16s had something like 10j wheels??!!) surely that would affect the car in the same way as fitting the ats cups would?
clifton
sorry to steal the thread...but i have some o.z superlegeras with and offset of et37...and i went to lkperformance and they told me i would need some 20mm hubcentric spacers...so i bought some..and im just wondering will this make the handeling of my car sh!t and will they rub standard arches?
johnnyboy666
i think that should make the offset just right but as to wether the rub the arches or not will depend on wheel diameter and tyre size i suppose
C_W
No because you're bringing the offset back to almost standard.
pdd144c
It really won't! Not for the track anyway.
johnnyboy666
pdd144c, do you run really wide rims? if so what affects do they have? and what offset are they?
ta
C_W
Mine are 7" ET11 and fit fine no rubbing, another inch to 8" is probably possible without any major modifications.
johnnyboy666
sounds like it could be possible then, thing is with it being a roland garros the arches arent the same as the gti's but with a bit of luck i'll get the arches snipped a little so i can fit the gti trim thats been kicking round my shed for ages :blink:
pdd144c
Yes, I run 16 x 8s, like all our 205 race cars do. Tend to use ford racing wheels, ET25-28 and use spacers as required. Currently have a spare set for sale :unsure:
Jrod
What are the biggest hubcentric spacers you can get? 25mm? or do they do 30?
pdd144c
We can make any size you require.
Jrod
Right well I will give you a call sometime next week probally.
I'm looking at some 15x7's et40 Do you think i'd need to run offset 0 with them or would 10 be ok?
Got to clear brembos aswell. :unsure:
