Jer309GTi 3 Posted February 11, 2007 I have a set of 206 14" steelies to go on the XS, with 185/40-14s on. The fronts fitted fine, but the back tyres hit the beam. Obviously I need spacers of some kind, but unsure of which ones to get and where from. Can anyone help me out please? Share this post Link to post Share on other sites
sonofsam 5 Posted February 11, 2007 Can you offer the wheel up, so as not to hit the beam, and measure the gap you have between stub axle and inner wheel surface to determine how much spacing out it needs? Spacers usually come in 5,10,15,20,25 and 30mm thickness. Or do you know what offset(ET) the wheels are? if you have a search on here mate, for 'hubcentric' 'wheel spacers' 'adaptors' they should be a good few companys name listed for purchase of spacers, I know, becuase I have listed quite a few myself Hubcentric's are the ones to have really as the have a 'register' for both wheel and stub axle and will avoid any misalignment wich causes wheel wobble. Share this post Link to post Share on other sites
Jer309GTi 3 Posted February 11, 2007 Thanks mate I reckon 10mm ought to do it, as you can still turn the wheels with the tyres rubbing on the beam. I don't know what the offset of the wheels are, I cant see the size stamped on them anywhere Share this post Link to post Share on other sites
sonofsam 5 Posted February 11, 2007 No worries, have a look on ebay too, you may pick up a bargain. item no: 230037460454 seems a good example. Looks like you can get 3,6,12,14,16mm etc too Share this post Link to post Share on other sites
steve@cornwall 100 Posted February 11, 2007 or fit gti drums? Share this post Link to post Share on other sites
Jer309GTi 3 Posted February 11, 2007 steve@cornwall said: or fit gti drums? Thats a good idea Would be cheaper than buying a set of spacers and longer bolts, and have slightly better back brakes too. Are the GTi drums more than 10mm or so wider than base model? I'll have a search for wheel cylinder compatibility etc, but if I can't find any info I'll start a new thread. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted February 12, 2007 Whats the offset of the steelies you have? It should be stamped on the rim centre. I don't think the GTi drum is 10mm wider than the base model one, the shoes are approx 5mm wider thats all. Graham. Share this post Link to post Share on other sites
Guest smokinslim Posted February 12, 2007 The cylinders are a different shapes on xs/base models and gtis, plus gti shoes dont sit correctly on lower spec backing plates because of the difference in thickness - i tried once lol. So if you want to fit gti drums you also need the backing plates etc. You can probably still get the lot from someone whos upgraded to discs cheaper than new hubcentric spacers. Share this post Link to post Share on other sites
Anthony 1,003 Posted February 12, 2007 Just pick up some 14" steelies from a 306/ZX - cheap as chips from a scrappy, will fit straight on with no fouling issues which is a better solution than spacers + longer bolts... Share this post Link to post Share on other sites
Jer309GTi 3 Posted February 13, 2007 (edited) Anthony said: Just pick up some 14" steelies from a 306/ZX - cheap as chips from a scrappy, will fit straight on with no fouling issues which is a better solution than spacers + longer bolts... Think this will be the cheapest option tbh. Its a pain because we've only just got the tyres put on the wheels and balanced/new valves etc. More money down the drain... Just noticed I put 185/40-14 in the original post Edited February 13, 2007 by Jer309GTi Share this post Link to post Share on other sites
