205_sunderland 4 Posted February 11, 2007 i made me own plate at work bout 20mm think and made it angled from corner to corner so should be more than enough, cnc'd the port's for better accuracy(with a little help fom me mate at work because i not quite fully trained on them yet) , the only thing i was woundering was if it would be best to clamp it to the manifold and plate together and grind ports in flush and drill and tap two holes to with countersinks to locate in the correct place all the time?, and i was going to use two gaskets, anyone shed some lite please as i want to car done asap now:) regards michael Share this post Link to post Share on other sites
jimbean 0 Posted February 11, 2007 hello there what metal u used to make it? could you not mig or tig it so it becomes part of the manifold Share this post Link to post Share on other sites
205_sunderland 4 Posted February 11, 2007 it ally so doubt it can be welded to mild steel? Share this post Link to post Share on other sites
Edd-XS 0 Posted February 11, 2007 If one side is machined flat the you can probably get away without using a gasket if its going against the block. Ive used one of matts plates and its a brilliant idea, but my god is it a pain in the arse trying to balance manifold, angling plate, gasket and sealant everywhere as you put it on! Attatching it to the manifold is deff a good idea I reckon. 20mm sounds abt too steep though if you ask me? Mine was probably half that and its cleared the bulkhead No problems. Edd Share this post Link to post Share on other sites
205_sunderland 4 Posted February 11, 2007 (edited) well i didnt know how much so i went for 15 degree roughly i think which is corner to corner so as long as it clears ill be happy:) Edited February 11, 2007 by 205_sunderland Share this post Link to post Share on other sites
sorr 0 Posted February 11, 2007 Ive used one of matts plates and its a brilliant idea, but my god is it a pain in the arse trying to balance manifold, angling plate, gasket and sealant everywhere as you put it on! It is really easy if you do it the same way I did. Put sealant on the plate and bolt it to the head, torque to the correct settings. Wipe the sealant off the ports, leave sealant to go tacky. Then remove the bolts (the plate will stay on due to the tack sealant) and on with the manifold and gasket. Hope this helps and it also ensures any excess sealant will not block the ports. Share this post Link to post Share on other sites
205_sunderland 4 Posted February 11, 2007 could be on the cards:) Share this post Link to post Share on other sites
205_sunderland 4 Posted February 11, 2007 can sealent withstand the heat though? Share this post Link to post Share on other sites
welshpug 1,646 Posted February 11, 2007 if its exhaust sealant yup! Share this post Link to post Share on other sites
205_sunderland 4 Posted February 11, 2007 sounds like a plan then:) Share this post Link to post Share on other sites
davev 1 Posted February 11, 2007 just to add. when i did it i got two of the old manifold bolts took the nuts off and used them as a guide for the angle plate and manifold to sit on. worked a treat as i went down the two gasket route and just couldnt balance all of them on the new bolt and locate it in the head at the same time. Share this post Link to post Share on other sites
petert 580 Posted February 12, 2007 Use Loctite Copper Maxx for the sealant and don't forget you'll need tapered washers to match the angle, otherwise you'll be continually doing up nuts in awkard places. I sell tapered washers and longer studs as part of my wedge kits. Share this post Link to post Share on other sites
205_sunderland 4 Posted February 12, 2007 i think i may make sum ill see how it goes Share this post Link to post Share on other sites
