robbiecfc
Power Steering?
robbiecfc
Hi All,
I've a 91 1.6 205 on a J which starts to grumble and hiss when I'm manouvering slowly. It is especially noisy when I've a full right lock on. Any ideas?
All bearings and track rod ends and bushes on front suspension have been replaced.
Thanks in advance.
j_turnell
An obvious question but have you checked the PAS fluid level?
Guest purpletoddy
nearly all cars that I have owned with PAS have groaned or similar when under load....does sound like the fluid may be throting with a bit of air in the pump.....as perviously said may be needing a bit of a top up
robbiecfc
Cool as. I did not check the PAS fluid level. An afternoon of 205 tweaking lies ahead of me I think.
Might be worthwhile changing the fluid before its degraded to far & the pump starts to squeal in use.
Graham.
