Spiky 37 Posted February 10, 2007 firstly does anyone have a part number?? also when i buy it do i use the std 205 resivior ??? or do i buy the 406 one???? Share this post Link to post Share on other sites
Powers 13 Posted February 11, 2007 I used the 306 gti6 one. As I think if i remember correctly (which is hard if your pissed!) the 406 one won't be level. Share this post Link to post Share on other sites
Alastairh 47 Posted February 11, 2007 I run a 406 one, and used the 406 resivior, but you can use the 205 aswell. part number, had a quick look on euro car parts : (non abs, 4 port) 132735130 - £70.30. Alastair Share this post Link to post Share on other sites
Spiky 37 Posted February 11, 2007 I used the 306 gti6 one. As I think if i remember correctly (which is hard if your pissed!) the 406 one won't be level. mmmmmm I run a 406 one, and used the 406 resivior, but you can use the 205 aswell. part number, had a quick look on euro car parts : (non abs, 4 port) 132735130 - £70.30. Alastair 70 i thought these were 40 something? Share this post Link to post Share on other sites
Discostu 6 Posted February 11, 2007 Stop complaining and get u'r wallet out Share this post Link to post Share on other sites
Spiky 37 Posted February 11, 2007 like wise....alternator Share this post Link to post Share on other sites
Spiky 37 Posted February 11, 2007 ok which one do i need??? Share this post Link to post Share on other sites
Discostu 6 Posted February 11, 2007 U'rs is a 1.9 so u need the 4 outlets. That wud mean the BMC4816 would be the one to go for.... i think Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted February 11, 2007 Out of the two I'd get the BMC 4816, the later one might have the mounting flange sat at an angle making it no good for the 205 servo. Graham. Share this post Link to post Share on other sites
Spiky 37 Posted February 11, 2007 ok cheers just tried to order one, but it dont like my address :S will ring tomorro Share this post Link to post Share on other sites
Normski 1 Posted February 11, 2007 I got the 406 MC (4816) from brakeparts the other week, £60 delivered. It fitted just like a standard MC and used my original fluid reservoir, fits just like standard. Share this post Link to post Share on other sites
Spiky 37 Posted February 11, 2007 I got the 406 MC (4816) from brakeparts the other week, £60 delivered. It fitted just like a standard MC and used my original fluid reservoir, fits just like standard. niiiice, that what i like to here Share this post Link to post Share on other sites
Anthony 1,003 Posted February 11, 2007 I personally use the 406 reservoir when I fit them - much better I find. Share this post Link to post Share on other sites
M@tt 77 Posted February 12, 2007 Might be worth noting that i found my brakes (307) started to bind when i fitted a 406 master cylinder it was due to the heat from the engine bay heating the fluid and causing it to expand and force the brakes on, i had to adjust the little rod thing in the servo to sort it (15 min job). There is a post on it by me if you do a search. Share this post Link to post Share on other sites
