laser green 1.9
Beam Rebuild
laser green 1.9
I've just put my beam back together. Unfortunatly I can't see the markings that I put on the torsion bars. Is there any other way of identifying the different torsion bars. I think I have found the original factory markings. There seems to be what remains of one yellow ring on one bar and two white rings on the other. ( 1 ring right hand torsion bar - 2 rings left torsion bar) Would this make sense.
I never took one end of my anti roll bar and when I've put it together the holes have lines up, if I put the torsion bars in the other way round the anti roll bar will not align with the hole in the trailing arm. Would this suggest that the torsion bars are only correct the first way around.
Wish I'd marked them up better now, ( I did stamp the ends of the torsion bars to match the trailing arms for ride hieght though.)
Cheers Mick.
Edited by laser green 1.9
Only the original factory markings if they are still visable or any marks you make before dis-assembly. (one ring = r/h bar & two for l/h is riot)t.
Other than that I don't think there are any identifying marks.
I'll check some tomorrow & post back if there are any more marks.
Graham.
nick
Arn't they slightly different lengths??
Nick
Nick
No, well if they are it really is a minute amount.
Graham.
nick
Righto, just me being a cock again...!
Nick
laser green 1.9
I've just gave the torsion bars a bit of a rub with some grease remover, the first pic shows what is left of a yellow painted ring.
http://i21.photobucket.com/albums/b297/las...en/DSC00703.jpg
The second one shows two or possibly three white rings.
http://i21.photobucket.com/albums/b297/las...en/DSC00704.jpg
I thought there are only supposed to be two rings but there you go, from looking at one of the torsion bar ends a know that it is the correct way round as it stands because I had to heavily wire brush and soak with plus gas on end to get the tosion bar out. :)
edit; file sizes, less than 120k please.
Edited by pugtorque
Guest Maikel205
both bars have (or used to have) 3 white rings on the same place, so these are useless.
309PUG
Just to clarify, each TB is exactly the same, there is no left or right as you descibe them. Other than the splines will be slightly offset in comparisson with the other bar.
Chris
laser green 1.9
Chris
Does this mean that the only problem would be that the trailing arms would be at a different ride hieght, and that their would be no problem with the action of each torsion bar.
cheers, Mick.
Chris
Does this mean the bars you sell are sided then Chris? If so how do I tell which is which?
Graham,.
