matt205xs
Wire Burning?
matt205xs
I havnt started the pug for 2 weeks, went to start it this morning, battery wasnt good but would crank, and the conenctor under the steering column, (6 pin one) got very hot and started to smoke?
what would have caused this?
gizzmo
most likley poor connection inside block visual inspection usually enough to locate the problem
matt205xs
opened the connection up and it was the main earth wire on that connection plug, it hasnt touched any other connections just blackened the connect, spryed with wd40 but car still not starting, all i can here is the starter motor clicking, are they prone to sticking in this sort of weather?
smugpug205
Flat battery try a jump start.
How old is the battery if there old a cold snap can make them finaly pack up.
Adrian
matt205xs
well the battry is only about 2 months old, but hasnt had a great deal of use, although i did borrow a friends charger a month ago and give it a good charge,
i have tried jump starting it, and made no difference what so ever,
i have put a multi meter on the battery and no ignition is 12v then on crank it drops to 9v is that correct?
smugpug205
That is about right, but voltage is only one element needed to start you car. You would need to do a drop test on the battery to check the condition overall.
Check the engine earths are ok if you have a jump lead go from the bettery neg to a good engine earth (starter caseing, exhaust mainifold) if it started after this whould show if your earths need looking at or it could just be your starter.
Adrian
