stuart_knight6
What Is This?
stuart_knight6
What is the thing I have circled in red? Is it supposed to hae steam coming from it?
Thermostat housing, and no, it shouldn't have steam coming from it - suspect that you've got a small leak somewhere around there.
Rippthrough
Thermostat, there's a bleed screw (allen key) on top, check that's tight, otherwise the gaskets gone between the two halfs.
There's a good chance you will have air in the cooling system now though, so rebleed it after solving the problem.
axnutty
Also worthwhile checking the end plate that the hose slides onto. They are pretty thin and ive had them rot through and perforate before in the past.
stuart_knight6
Thanks for all your help guys. Will check it whilst servicing.
