frodo_monkey
Cylinder Head Spacers
frodo_monkey
Just putting the head back on my 1.6 engine and need to know an answer before I bugger it up...
I know the head bolt above the waterpump needs the 25mm spacer, does it also have an 8mm spacer as per the rest, or is it just the one big spacer?
Cheers! :)
Yes, there's two spacers above the waterpump - one thick, one thin. The other nine headbolts have a single thin spacer each :)
frodo_monkey
Thanks Anthony, you're a gent :)
Off to put the bolts on... Expect an update of my engine build tonight then :D
Si
