inferno 1 Posted February 8, 2007 can anyone explain to me an easy way to put a bias pedal box together? do i bolt th pedel in first? do i wind the knuckles on the MC,s before fitting the threaded bar? im stumped, whatever i try leaves the MC's at silly angles:P also a quick guide on adjusting and setting up before first drive would be usefull. thanx a lot. Share this post Link to post Share on other sites
bren_1.3 1 Posted February 8, 2007 bolt the pedal in, slide the threaded bar through the tube in the pedal, and then attach the MC "knuckles" clevis pins to either side of the threaded bar. line the clevis pins up centrally with the holes you've cut into the box for the master cylinders, and then screw the MC's into the clevis pins with the locknuts attached from the other side. then bolt the MC's to the box itself. job done hopefully....... Share this post Link to post Share on other sites
inferno 1 Posted February 8, 2007 this is proving most annoying now... one cylinder keeps going down first... oh well ill keep trying Share this post Link to post Share on other sites
Rob Thomson 6 Posted February 8, 2007 I wouldn't worry too much about that, it just means the friction of the pistons in the bores is different. What matters is how they move when they're bled. Make sure the push-rods are similar lengths and you shouldn't have any problems once it's fitted. Share this post Link to post Share on other sites
Rob Thomson 6 Posted February 8, 2007 Also look here... http://www.rallydesign.co.uk/catalog/balancebar.php Share this post Link to post Share on other sites
Craigb 2 Posted February 8, 2007 (edited) inferno said: this is proving most annoying now... one cylinder keeps going down first... oh well ill keep trying is the system all new ? If so have you bled the brakes ? Also make sure that the pivot is moving across the balance bar. Check that the bar is not binding PM me your email and i will send you a diagram with the correct spacings Edited February 8, 2007 by Craigb Share this post Link to post Share on other sites
inferno 1 Posted February 8, 2007 great site rob, craig its robs old unit, but looks in pretty good order now ive reshaped it a little:P just dismantled it all again after getting it right, as it doesnt fit in the hole in bulkhead fully assembled like the normal one does:O Share this post Link to post Share on other sites
blackpug 0 Posted February 8, 2007 Mine didnt go in without a fight! I took a big hammer to the top and bottom edges of the bulkhead hole to make enought room. Share this post Link to post Share on other sites
Rob Thomson 6 Posted February 8, 2007 inferno said: just dismantled it all again after getting it right, as it doesnt fit in the hole in bulkhead fully assembled like the normal one does:O From memory I thought the only thing you had to remove was the clutch pedal, and then it would go through the bulkhead (at and angle) without any probs? Share this post Link to post Share on other sites
inferno 1 Posted February 8, 2007 oooooops... looks like im taking it out again then lol... nightmare, i put the box in and now need to wind the MCs into the knockles in situ:P dont i love making my life hard:P Share this post Link to post Share on other sites
