M_R_205
Which Sensor Is Which?
M_R_205
my engine is currently away geting sexed up and i decided it is worth replaceing all the senors at the same time, i know what all the ones on the block do (thanks too richie-van-gti :D ) but the now ones on the theromostat housing are taking the piss out of me
cheers in advance
Paul
Ryan
From left to right:
1. ECU coolant temp
2. Don't know
3. Dashboard coolant warning light switch
4. Dashboard gauge temp sensor
M_R_205
no one know what the seccond sensor is???
Bonzai
seeing as you know what the sensors on the block are, and i cant be assed to search, what are the two sensors on the front of the block above the oil filter? one small one, one big one.
Ryan
If it was screwed into the bottom of the thermostat housing then I think it might be part of the mi16 aircon wiring.
sonofsam
Oil pressure sender and warning light.
