Spiky
[trackday_prep] My 205 GTI-6 Supercharged Track Car
Spiky
well, had a few hours at llandow, then came home and did some wiring and bits and peices on the 205
had to make a new loom, for the sensors/alt/starter becuase that wiring went with my ecu loom
also nipped a bit off the sump so i can lower my rad :rolleyes:
DrSarty
There doesn't appear to be any protection (such as a grommet) on the wires going through your bulkhead (!), or is this just a test fit?
Spiky
good spotting :lol:
to be done :rolleyes:
dcc
Spike!
Whats with the be1 box?
Spiky
what you asking?
its a be1 box and works fine :rolleyes:
309PUG
Hi Steve,
Did you receive my PM regarding your uprated ARB ??
Chris
Spiky
paid and replied dude :rolleyes:
did you sell the 309 ?
309PUG
paid and replied dude :)
Yep,
Guy from Heathrowe bought it over the phone unseen, his cousin came up with cash just to collect it ;)
Chris
Looking at selling Rachels 04 plate Focus and buying an Golf R32 :unsure:
Spiky
ah good choice :unsure:, sad news you sold it :)
philfingers
Yep,
Guy from Heathrowe bought it over the phone unseen, his cousin came up with cash just to collect it :ph34r:
Chris
Looking at selling Rachels 04 plate Focus and buying an Golf R32 ;)
R32. Look after it. Thieving scum bags put a young kid through a window about 8" deep at my brother in law's house and got him to get the keys off the table for his R32. He got it back 2 days before pay out. carpet was soaked in coke, old chips, they'd smoked in it. He was gutted, obviously
Spiky
well i've done a little more work on the car recently,
all i'm waiting for now is my ecu to turn up, but god knows when that is :(
but the rest of the car is pretty much back together :P
bought a new filter for it :lol:
fitted my new HT leads and a coil pack ;)
so many wires :(
bought a wide band lambda gauge with the controller and sensor, so fuel economy should be improved :D
Spiky
not much room now lol
more wiring
above was a slightly older pics
todays pics are as follow :P
Spiky
SteveW
Looking good dude, hurry up and get it fnished cos mine is next on your list hehe
Spiky
lol
tracktoy
getting there dude, hope that ecu turns up in time
its gonna sound awesome :lol:
Spiky
made a bracket to hold the rad at the top, to giive a tin amount of strength to the front as i wont running a slam panel now
SteveW
has it enough clearance for the flappy bonnet?
djinuk
with regards the afr setup mate.. be very cautious with using the lc1.. the rtoc boys are very large fans of wideband as it allows them to up boost whilst monitoring the fueling and thus prevent headgasket failure but many had lc1 gauges through a group by and had a lot of trouble so innovate allowed them upgrades to the lm1 setup which i also have and have been fault free.
Also be warned dont use the gauge constant , only to monitor/setup as they have limited life spans. You probably already know that anyhow but i just wanted to make sure :wacko:
Still gota setup my lm1 in my r5, its just sat in its box, all new and clean :wacko:
Spiky
you mean remove the lambda sensor?
or just the gauge?
djinuk
the sensor mate, i think the life span is 50 hours + , obviously not really ideal to be fitted all the time. You should get a bung in the kit i believe that can be screwed into the lamda bung. Its a mistake i almost made in thinkin ah ill fit this and if anything ever goes wrong with fueling ill spot it but was quickly corrected :wacko:.
Spiky
thats a bit crap, if i want to run closed loop, as the sensor will need to be run all the time
djinuk
not exactly sure on what a closed loop is, but yea it is a bit crap. It may be false information as i was only passed it on from a friend however be prudent to find out :).
tom_m
50 hours is the lifespan if using leaded fuels. on conventional unleaded you should be expecting a life span of around 500 hours
swordfish210
It means that the ECU is adjusting the fueling and the ignition by taking a reading from all the sensors, an ECU in a road car will run like this when the car is warm. Open loop means the ECU is controlling the fueling and ignition but only taking a reading from a few sensors, temperature related i think but not the lambda, it will run like this when the engine is cold.
Something like that anyway
