Spiky
[trackday_prep] My 205 GTI-6 Supercharged Track Car
GLPoomobile
Not really much to add that others haven't said above (more succinctly than me too) except to quote a sentence from the Capri restoration thread on the Turbosport forum (I have to quote this again as I really like the sentiment behind it)
Experience is what you get when you don't get what you want
Like you've said, there's more than one way to skin a cat. If you want to do things differently, sometimes you'll fail but at least you've learned from it. If you are successful, you'll still get resistance from those who choose to play it safe and go with conventional wisdom, but at least it's worked for YOU. Ultimately you might be the one changing conventional wisdom and re-writing the rules. The comments that you feel are being aimed at you negatively may be coming from those who have learned from their own mistakes and are trying to help you avoid those mistakes, but (ECU debate for instance) if you feel that your way is working fine and don't wish to change, then don't. The outcome will either be that you'll ultimately fail and realise that the advice you were given had an element of truth to it, or you'll be fine and prove to yourself that you were right (but unlikely to change the minds of the doubters :angry: ).
I'm sure if you are honest about it for a moment, you'd admit that the good advice and things you have learned here far outweigh the bad advice. Don't they? :) . Some things (like suspension settings) can be so subjective that there will always be a risk with them, and unfortunately they can be expensive mistakes to learn from. That's life.
You can tell it's nearly Christmas, I've been far too diplomatic of late :):angry:
marksorrento205
Bloody hell just read it from start to finish. You lose track of dates and its like you have done it in a week or two, not nearly two years. Good work - its answered a few of my questions too :)
Edited by marksorrento205
Spiky
Surgie, as per craigo, comments weren't aimed at you :)
cragio, dont worry about the can of worm's, think people just need to blow off some steam..lol
GLPoomobile, xmas DEFINATLY calmed you down...lol, of course people like me will do something sometimes fail some work, but its people like me that dont follow like sheep just becuase someone has been doing it for years. but these old timers dont seem to like "change"
and no the ECU will still be there until the car is dead,,lol
Marksorrento205, glad i could be of assistance :)
weejimmy
this was a great project thread,
shame its a cat fight now like so many good threads on this forum.
what a waste
Spiky
yeah, was a shame dude :D
was just out driving it :P
weejimmy
ok for some,
im still gathering parts for my track car,
have to make do with abusing the stdt for now
dcc
where are you based spike?
Spiky
couple a miles from cardiff, :)
Spiky
Well it's xmas so decidede to show what i have done, as it's all running now :)
starting to see end of the tunnel now, lomst everything is back on the car
Left to do now
buy a new set of 309 wishbones, so i dont need to rush to make the ADJ one's
exhaust still needs to be re angled to fit the newly positioned ex manifold
screen fitted to the rear hatch.
buy and fit new SRF brake fluid
fix TPS wiring
buy and fit 76mm 90 degree pipe for airfilter
buy and fit std 8v water top hose
Edited by Spiky
Spiky
not much left to do now
I bonded the screen in the rear hatch
picture from above, :(
and here is how i setup my topmounts for now :D
New sensor for my new gauge :)
and the new modified downpipe loads of clearance, even though he picture probably doesnt show it :D
Spiky
FG rear hatch now fitted :)
well finished off all the wiring now,
rear hatch just needs a black border painted on to hide the sealer underneath,
need to tighten the wishbones bolts
need to bleed the rear brakes (will do later)
waiting for a water hose so i can fill the car up with water/antifreeze
Spiky
well took the car out for its first drive monday,
all ok :( engine holding water :D
clutch needs slight adjustment :D
no knocking having the top mounts underneath , though see pic below for reason..lol
however the brakes :o . fook me i need bigger muscles :)
i bought a new 90 degree pipe so i can mount the airfilter down out the way, and will box it in, so there is no heat soak from the rad and no splashing from the wheels :D
ride height wont stay like that, i just raised it so it dont knock, will be lowering it next time i'm out there :D
Bas
Spiky,
Was there a lot of rattling and noises from the polyester hatch and poly rear window?
( I am very tempted to buy the poly hatch and window, only I use the car on the road as well, so I want some comfort left..)
I"m getting a poly bonnet. (with the same (BIG and UGLY) aero catch locking kit)
Have not installed the aero catch locking kit/poly bonnet, but I am thinking of spraying those BIG and UGLY aero catch bastards, white. (my 205 RFS = also white)
I have the same setup for the airfilter, BUT when hot (and fan kicking in) and idling, my RFS begins to misfire, I think it's because hot air from radiator fan blows into air filter...
(already changed: coil packs, map sensor, generator)
Spiky
air from my rad wont beable to get into the aitfilter as there is going to be a deflecter plate in the way :lol: its to stop heat soak too
car sounds normall with rear hatch as it is :)
Craigo
looks good spiky, bit moon buggy style tho!! :D
Spiky
its just incase i go in gravel traps ...:D
Bas
air from my rad wont beable to get into the aitfilter as there is going to be a deflecter plate in the way :huh: its to stop heat soak too
That is a good idea!
car sounds normall with rear hatch as it is :lol:
Ok one more thing on the wish list :)
Bas
Some solutions I came up with for the 205 RFS:
Windscreen washer bottle:
ECU housing (chopped Xsara Box)
Wedge plate for exhaust manifold clearence
Exhaust manifold clearence
Spiky
love the washer bottle location :rolleyes:, great idea
god angle plate too, does it now sit on std mounts?
Bas
My 205 had headlight washers and a filler cap in the bonnet plate.
That's how I came up the idea.
Just tried the original washer bottle and tadatada
Yes only solid rubber bottom engine mount. (205 diesel i think)
Any plans to make more of them? I'll buy one if you do...
philfingers
Great thread Spiky, loads of info. Given me some incentive to do one myself. . .. . maybe start tomorrow!
Spiky
thanks matey :rolleyes:, need any info let me know :)
