Spiky
[trackday_prep] My 205 GTI-6 Supercharged Track Car
ROFL, you haven't heard a 306 with one fitted then!!
well they're not that bad but are under the DB limits.
Spiky
no, not heard one :), so stand corrected on that :)
guffe
How much is did the doors loose weight?
Spiky
will weight them later :)
Matt Holley
Ive got one on the 205 and 306 and the 306 one is alot louder, mad really as its the same engine and the 306 has a cat aswell, my 205 is about 93 db so very track friendly :D
I cant even hear the exhaust over the induction noise B)
Spiky
wow, thats mad...lol
but puts my mind at rest knowing track days wont be affected :)
Spiky
cut out section of panel with electric window mechanism and handle and window weigh
9.6kg'ish
new poly carb window is 2.5kg
so 7kg's a side :) :) :D
guffe
so 7kg's a side :):D :D
Damn, I want poly carb windows too, but then I can forget about ever passing Finnish MOT :´(
Spiky
get a second set of doors
only 5 mins to swap them over :)
Rich_p
Spikey,
Any chance you could take some pictures of how you have fixed the windows in now please?
Also I am going to chop the insides from my doors. What have you done about the sharp edges that are left?
File them down or have you taped them up etc?
Spiky
windows not secure yet, i have somes days off now (starting tomorrow), so want to get lots done on the car,
will be buying some nuts and bolts tomorrow to sort the windows
as the edges, will pass the drill grinder over them, and then i might just tape they up, or get hold of some sticky rubber and fold over the edge
VisaGTi16v
To fit my home made perspex windows in I cut up a door rubber into a load of small inch long pieces then put the window in the frame and used bits of the door rubber ever 5 inches or so pushed into the frame gap from the inside so holding the window outwards. I also drilled 3 small holes along the bottom edge and put 3 tiny nuts and bolts through from the inside then just did a layer of silicon sealer around the frame from the outside, been waterproof for 3+ years now!
309PUG
Get yourself a copy of the 'Car Builders Solutions' or checkout there website www.carbuildersolutions.co.uk they sell all types of rubber trim to finish off your sharp edges on your door internals, it's not expensive only £2.50 / m
chris
Edited by 309PUG
Spiky
awesome, just the stuff i need :lol:
just fixing the windows in now :)
cybernck
you could do it like this:
Spiky
yeah thats the stuff i want
Spiky
well the front windows are in,
happy with the results :lol:
4m stainless steel bolts hold them in place
even washed the inside of the door...lol
last picture is from the outside :)
Edited by Spiky
Spiky
ok, a little update on the 205,
i have modified the TCA's so they sit futher in the car, the inner rear is welded in place while the inner front is still adjustable :)
and we cut and re-welded the outher sleve further out so there was more threads inside the insert for safety, due to us having the arm further in
Spiky
here is my new rear hatch, quite please with it (although it took a while to get here) and i still haven't had my bonnet
and here is what it weights :)
projectpug
Looks like i shall be ringing them up as soon as i can then for a hatch looks good,
Spiky after testing my bonnet around anglesey on saturday 4 pins isn't really enough as in the middle it starts to wobble quite violently so going to put 1 more in the front at the middle. Hopefully reducing the shaking/vibrations.
Fitting is easy really just have to have the patience to make sure everything is allingned well before any marks are made. I got my dad to lend a hand as it would of been a lot more difficult on my own. A trick i used to get the holes marked up on the underneath of the bonnet was a spot of red paint on top of the pins and gently lowered it to the marks i had made with masking tape so i knew it was marked exactly. The little red dots were very easy to spot on the back underside of the bonnet :). Then got to work with a 1/8 drill and kept checking the fitment as i went along drilling/flling the holes to the sie of the pins. Any more info then PM ...
Phil
Edited by projectpug
tom_m
whats your rationale for doing this, if you don't mind me asking spikey?
Spiky
Phil
mmm, was hoping 4 pins would have been enough :D as 5-6 looks a little rubbish :(, maybe i'll strengthen it in the middle then
cheers for the heads up though
bascially becuase they didn't fit, he has sold arms after the group buy, rung the customer and they fitted fine, so i just modified mine to fit my car
Spiky
well started to finish this off just now
and
pack for the ring :)
new door handles ;)
new beading around the doors
fitted my helmet net,.... at loooooong last...lol
Edited by Spiky
Spiky
madant_uk
looking good, thanks for the PM mate, will be doing the same to my doors, hope you enjoy the ring
