Spiky
[trackday_prep] My 205 GTI-6 Supercharged Track Car
Spiky
my new bits turned up today
from the group buy ;):D:D
cheers Tony :blush:
roland rat
spoke to your bother adam earlier about how the build was gonig and ive just read all 26 pages!!
looking good mate,shame adam doesn't share the same mechanical knowledge you do :)
Spiky
he'll get there eventually :(
nice quick read for you then...lol
i bought some new springs at combe too, 7" 300lbs should stiffen the front end up a bit :(
only tonight did i rip the front suspension off to fit the adh track contrl arms...
Spiky
took the front suspension off this week, to fit my new springs
removed my 9" 185lbs springs and fitted my new 300lb 7" springs
lube'd up my tubes with vaseline too :D and all the rose joints
fitted my new adjustable track control arms too, so just needs setting up now,
next track day is croft RS day so got a while to sort the suspension settings out
probably going to set it up for around 1.5 - 1.8 negative camber :D
also purchased some Dunlop wet slicks too :D
think it needs a wash after my last track day at combe :oops:
Spiky
well as you can see from the earlies pics, it was a bit dirty, so i gave it a clean :ph34r:
VisaGTi16v
Did you find the cause of a clunk you mentioned somewhere in the front end?
I hope you put the bolt back in -
:D
Batfink
you've chosen wet slicks over something like the Yoko Ao48's???
if you intend to run these in the dry make sure you speak to Dunlop about opporating temps as they will be at risk of overheating and deteriorating at a fast rate
swordfish210
We used to run these tyres on the Radicals in the Dunlop Great and British champoinship. They'd do a 25 min race in the dry without too much of a problem, but they're heavy and nowhere near as grippy as the equivalant Avon wets.
pugbender
hi is it possible to know the diameter of the rose joint of the hub side and internal side?thank you and the car looks amazing!
Spiky
bought a few things for the pug this week
a proper 1.6 box, (had 3 all had various issues)
but will fit this after the ring trip
strut brace
polycarbonte windows
passenger foot rest
some driving gloves
projectpug
We now have identicle windows and driving gloves hehe :P
Spiky
Just been out and done some cosmetic changes :blink:
really happy with the results :lol:
rossi
Looks awesome that Spike! Shame i didnt see it in the flesh!
Spiky
yeah, was a shame dude,
how is yours now? all sorted???
rossi
Pretty much yeah! Just got it back today from MOT, it now brakes! Runs well, just to fit the BBM kit and it should be ready for the roads. Just need clean out the stepper motor tomorrow, was stalling tonight on the way back at low revs.
Due to the lack of work in the building trade at the mo, it'll be sometime before I insure it :-/ Gives me more time to work on her though, which is good while i'm off work.
Spiky
well the car is too heavy, so i've put it on a DIET :(:D
stage one of it's diet
Is the door holding together where you've cut below the glass? Most stripped out doors I've seen still have the ~10mm strip with the spot welds left on and it looks like you've cut them off.
tom_m
have you driven it in anger at that ride height? how does it feel? you can't have an awful lot of travel left with the bilstein coilovers that low.
mine would be on the stops at that ride height.
Spiky
yeah i may have trimmed it a bit to much, but should be ok, i'm only going to add a few tack welds near the hinge area :)
they car did 2 full days at croft like that, seems fine :D
VisaGTi16v
My doors are like that to and the boot lid although I have the offensivly heavy mirror adjusters to cut off as can be seen in this photo :)
Spiky
cool
less is more :)
Spiky
More new bits :)
magnex
VisaGTi16v
Whats with the 2 boxes? I have a straight through pipe to a single Grp N OMP back box and its about 97db, 2 boxes=more weight!
Spiky
thats good news then
it will be quiet :)
magnex are usuall quiet , as they copy the OE systems :)
