Spiky
[trackday_prep] My 205 GTI-6 Supercharged Track Car
Spiky
i need to have a think, as chatting with alex, it might be better to jsut sell my omp and get a custom cage?
Spiky
what you think of the possible new colour scheme?
philfingers
SPGti had Mark at Jam Motorsport do a mod to his cage, extra diagonal and narness bars and the price wasn't prohibitive and he made a good job too. there's no reason for not adding the bits, so long as it's done properly.
Phil
philfingers
nice colour, what is that? Always like that and sort of pastel blue too
Spiky
my welder is very good at it, so doing it isn't a problem, but as i'm taking strenght from my cage maybe i should get a better cage all together
will have a think.
i jsut asked someone to copy the new focus RS colour
projectpug
Remember Spiky the more cage you add the more weight you will add too. The new rear section sounds good though that would incorporate the harness bar etc.
VisaGTi16v
Not sure where your current rear belt mounts are but can't you do something similar to my Visa which has 2 holes in the floor with some big plates behind (ie underneath) with the eyelets bolted through them. It got a msa log book fine so should be ok (my rear triangle doesnt come back that far now, modified to be inline with the rear struts as per the sprint regs that it was breaking which took 20+ events before a on the ball scruiteneer told me!)
http://www.visagti.com/pics/sprint/new/9.jpg
Spiky
in the pictures above/other page i have put ring bolts int eh old seatbelt mounts :)
philfingers
I think you're better of with a harness bar in the cage. You're not really adding weakness by putting the bars in and it would be far safer than what you've done now and what you had before, so long as you'r proficient with your welder. Basically what you've done now (and what is also very common in a lot of 205s, I'm not pointing the finger, you're brave enough to take the abuse) is angled the belts too much (as Tom has said). In extreme cases of heavy impact they could rip through the upper seat harness holes and crush your spine. It's unlikely but it's possible, which is why there are max installation angles spec'd and why it should be avoided.
I understand you're not after an MSA logbook but their standards are only there for safety reasons, take advantage of them.
I ran mine like that (to old seat belt mounts) for 4 years, before installing a mounting bar and finally now a C44 cage
Phil
Edited by philfingers
Spiky
i'm 100% with you, and that i want them away from the floor as soon as possible, but it's what i do,
1 get my mate (as i dont do welding) to weld a new rear section to my omp cage and well all the feet the same time
2 get a new cage (£600 :) )
Dj_mini
Where the hell is all that weight hiden? my old car with an mi and full weld in cage weighed 775kg's on colins scales thats fully road legal trim with all the dry sump gubins i had i cant see the engine weighing alot less than your gti6?
Edited by Dj_mini
Spiky
i dont want this to sound off, but are they accurate?
800 i could except for your car, or maybe a touch more, as i have the gti6 and is 25kgs heavier, i dont see rhe dry sump weight that much (though i am guessing here)
i'm as supprised as you as to the weight
what else have you done to the car, that i haven't to make it lighter?
tracktoy
1- keeping the front half you have and adding a new rear section would be comparatively cheap, give you the design you want and not add any significant amount of weight as it would not differ vastly from what you currently have, just be better positioned
2- would be slightly lighter as theres no nuts and bolts and associated fitting to consider and could be made from lighter tubing than the omp but not sure you would gain that much over option 1
it makes no real sense but it must be fairly accurate to be the same on two different scales- the only way to get an accurate figure would be to get the car corner weighted
Spiky
buying the cds isnt a problem
but paul, who can do the ends? so that they can be weld together? alimax? (spelling)
tracktoy
isnt t45 a better lighter spec? ends could be done on the miller, spindle sander or could rig up a tube notcher not too difficult- ailmax is not so local any more
ps how do i set this up to email me of replies to the thread?
Spiky
t45 is lighter and stronger i think, will have to find a supplier :lol:
will sort your email notification now :)
Spiky
email notification sorted now :)
as is fast reply (box at the bottom of a thread)
and you have 1 PM from someone, didn't look who..lol
Dj_mini
That was on colin satchels corner weights so its about as good as it gets.
I recon the dry sump added 10kg's with all the pipes remote oil filter bid oil tank and to catch tanks and 10L of oil
I had no heater matrix half dash light wheels 4pots a half sized fuel tank ect but i wouldnt say a lot less than yours seans who use to post on here was around the same weight as mine but he had an 8v so saved a bit there.
I know sandys 1400 he prepares was in the low 700's when itv was first built :)
If you want the cage tube let me know the length and angles you want notched on it and i can get that sortted for you. You cant mix t45 and cds mind. The corsa tarmac rally car that i spanner for has just had a T45 weld in cage / new shell done for us by ian @ dv8 metalworx the shell weighed 215kg's when we weighed the bare shell with the cage in!
Spiky
ah fair comment, they should be spot on then :), will have to find a place with some and get it weighed yet again..lol
whats the reason for not mixing t45 and CDS, if it's safety then i will just get CDS
crist low 700's thats awesome.
would it be easier for me to just drive to you, make the tubes up and leave? that way the tubes are right and wont need modding afterwards?
there are still area to loose weight, but money is holding me back, so they will happen over time, as of when funds allow, or parts turn up cheap
tracktoy
cheers dude,
just having a read back through re the lotus calipers, if you wanted to keep the gti6 disca you could always add a spacer behind one of the pads to take up the extra width- this would also help to move the caliper away from the face of the wheel
Dj_mini
The two metals react in diffrent ways so you cant mix them and you should realy tig T45 . The T45 does make a massive diffrence if you go for a full cage in it.
Ill check with Ian @ dv8 if hes happy to to it but im sure he can squease it in for you.
Craigo
dibs if you sell the OMP cage, now where's the crying smily like on passionford, lol :)
Spiky
cheers dude,
no probs,
alex is having one of your latest wheels tonight, we will base the mouting of the elise calipers on 307 hdi discs's the same thats on sarah car..lol
ok, wont mix then...
if you could find out that would be top, shall i get the tube in advance and then come down with it and he make them fit (but not weld them in place)
i suspect IF i do sell, Paul (tracktoy) will be putting the cage in his..lol sorry dude, but if he dont you can have first dibs :lol:
Dj_mini
He will have cds in stock so can supply the tube if you wanted. Ill get over and see him fri or sat then let you know if / when he can do it
tracktoy
no probs,
i suspect IF i do sell, Paul (tracktoy) will be putting the cage in his..lol sorry dude, but if he dont you can have first dibs :)
how do the 307 discs compare?
will deffo have the cage if you decide to sell dude- cheers
