Spiky
[trackday_prep] My 205 GTI-6 Supercharged Track Car
SwedishBob
I'm going to fit mine either in the passenger footwell, or in the passenger rear qtr
here is what i bought, i'll get more pics later if you want???
it came with pump, pipe, button to use it (but not needed as i will run with the OE wiring
Think that I'm going to copy your idea.
Spiky
i just means all the wiring will run along the wing and keeps it all tidy :wacko:
i may ask for rotalties if more people copy ...lol :blink:
Garry
Good idea Spiky, something else for me to copy! keep it up ;)
My relays and power box are currently near the header tank, which means they get wet from time to time <_<
Spiky
and imagine the weight thats in the washer bottle, which is now in the back of the car...??
lol.... thats a joke by the way..lol
VisaGTi16v
No joke! it all helps heh. Visa is quite different in that area to its half sister. Brake servo is on the passenger side with a pedal bar so no clearance issues with the master cylinder and cylinder head. The header tank itself is on the drivers side and the washer bottle is up by the bulkhead on the passenger side
Spiky
why dont you move the battery, that would give you room for the air filter then <_<
My mates header tank split slightly when we were on a trackday recently, it aimed a jet of coolant straight at the horn relay and the first we knew of the problem was the horn blaring under braking and during right handers ;)
VisaGTi16v
There is room for the filter and its back in the "normal" place since that photo however I may move it back. Thats a big air box at the front of the screen on the Visa which feeds the side vents inside, only middle ones come off the blower. You get a ridiculous amount of air through them when driving, plus its cool, no heat soak etc. Bottom of the screen/top of the bonnet is a big high pressure area hence why it gets so much air in and hence why I crack up when I see people lifting the rears of their bonnets as no hot air will escape because of the high pressure above and low pressure under! I plan on moving the battery but not had time or money to do it yet, other things more important <_<
pip470
I always thought if the air was moving over the top surface of the bonnet faster than the bottom of the bonnet it will cause a negative pressure on the top surface and a possitive pressure on the under side of the bonnet, effectively lift. Or another way to look at it is the air passing over the rear of the bonnet draws the air from under the bonnet. In effect sucking it out or pushing it out depending on perspective.
VisaGTi16v
The air does move quickly over the bonnet giving lift but then it hits the windscreen slowing it down massively giving downforce from the base of the screen up until it speeds up once on the roof so it makes it tricky for the air to release up from under the back of the raised bonnet due to the pressure area at the base of the screen. Im sure some gets outs and the more going into the bonnet from front end venting, means more to come out so it will find a way. Getting a bit OT but I read a article somewhere where they got a car and fitted a flat tray from the front bumper under the engine and it did make a difference to the cars performance and fuel use due to the better air flow underneath, ie things like the Clio 197 etc having rear diffusers now to get the air out quicker, look at an old 911, almost totally flat floor, my visa however is a joke, bits hanging everywhere heh
Spiky
the guys in the RS scene have the bonnets raised, with great results, and see their ACT's lower, due to less heat soke <_<
Spiky
sorted the aerocatchs on the bonnet now, so will take bits to be painted tomorrow :D
Spiky
Time for a little update, the engine is a little closer to being fitter, just need my pedal box painted and fitted and it can go back in :lol:
swapped the Quaife over into a 1.6 box and gave a lick of paint
Had the valance painted :lol:
Rear hatch painted :)
bonnet painted :D
Spiky
Changed my mind on the cabling, it was starting to look cluttered, so moved the fuse box's and relays inside the car now :lol:, as you can see look much better :lol:
My new expansion tank, as the old one wasn't see through, so couldn't tell if there was any water in there, or if it had mixed with oil :)
Had the battery tray powder coated, as it was looking very minging..lol
here is my new washer bottle, and the new location for the fuse holder and relays :D
Discostu
Very good work there Spikey, i am taking notes... ... :lol:
Once my engine is ready to go in you will be popping down mine to offer words of wisdom lol
Edited by Discostu
Garry
Looking good Spiky. Can you give me a rough idea of the powder coating costs?
Spiky
the ARB and brackets cost me 15
the battery tray + ( friends battery tray, wiper arams (under scuttle panel) towing bracket) cost me 30
the gearbox i painted with silver hammerite..lol
tom_m
which company did you use? someone local or a post off jobbie?
Edited by tom_m
Spiky
just a local company
springs
thanks :) saved my day that has
stuart
And mine too, been looking for something like that :)
Spiky
glad to have helped lads :D
Spiky
well big update, :)
Paul has made me a pedal box.... looks awesome too. :lol:
painted it the same colour as the engine bay.
this was the last peice needed so i could re-fit the engine, so 90 mins after assembling the pedal box.
woohoo engine and box back in :D
