Spiky
[trackday_prep] My 205 GTI-6 Supercharged Track Car
Spiky
mail me and i will post after football
spiky.steve@googlemail.com
Spiky
If you want to run at a lower ride height you wind the bottom platform of the coilover down, you will eventually run out of damper travel, and run on the bump stop. If you run the top mount above rather than below you can wind the bottom platform back up for the same ride height, and gain a further inch in travel.
Can I mail someone a photo of my setup to add to this post, I have taken this one step further.. ;)
are here are your pics
SwedishBob
Sorry for OT but is it possible to get some more pictures of that car? It looks really interesting.
Spiky
well decided to give the whold engine bay a lick of paint, so most of it is out
can you tell the difference between the RJ's? one is 4x as expensive as the other?
Spiky
Bought a 309 ARB and sent it off to get powder coated, looks OK,, bit pitted in areas but overall i'm happy with the job :)
Edited by Spiky
arnold naber
Looks nice spiky,
The pitted you ahve happends some time with rusted aera's..the powder coat reacts with it..
fitted the aerocatches on you bootlid yet ?
Spiky
yeah, it's looks much better as it is, so i'm happy :angry:
no didn't get chance :lol:
tonight i'm in the garage, hoping to get the bay sanded and maybe primer on,
if i still have time i will have a go at the rear hatch :lol:
Spiky
had a few hours spare, so rubbed the bay down a little, and gave it some no rust stuff and etch primer, and some normal primmer
it's not going to be the best of jobs, as it's getting done quick but should look a bit better :rolleyes:
her are some random shots
Spiky
now i have a small issue, i want to put the aero catch on the rear, but the very end of it will not be flat with the tailgate, would this look stupid? even if i was to take up the gap with some black polyuthrene sealent?
here the issue
taylorspug
It will look a bit pants like that imo. Can you not run a bit of heat into the plastic as you screw it down and mould it into shape?
Spiky
thats not a bad option..
i've been having a another look, and i think i should be able to move it over a touch more :rolleyes:
so will see
will they not fit at 90 degrees to what you have them now?
Spiky
not checked
BRB...lol
Spiky
yeah, they would actually fit that way :rolleyes:
:rolleyes:
arnold naber
Hmm.. o you could fit the aerocatch..
im a bit curious how you fit the (horizontal /vertical) because i could find enough room :rolleyes:
Craigo
love your car spiky, its inspirational!! :rolleyes:
Spiky
i wouldn't called it that last night ...lol
thank god for my gas heater, wow it would have been damm cold otherwise.
hopefully get tghe rear hatch fittings done this week, then the bonnet, then send them and the front valance off for paint :rolleyes:
then finish painting the bay and get the engine back in :)
Spiky
Done some work on the car tonight :):D
gave one side of the engine bay a lick of paint, then run out....pmsl
and i fitted the aerocatch's into the rear hatch, quite pleased with the results :(
Spiky
well went and got another can to finish 3/4's of it off now, so only a section to do, and the new tunnel :P so will get some more paint for that
here are more pics, i used the digi cam this time not my phone..lol
Edited by Spiky
Peetypug
looking good matey :P
when you planning for this phase to be finished?
Spiky
once painted, and pedal box back (mate copying it) the car is going back together and will enjoy it :P
nothing else i need/want to do :D
Spiky
as the painting has finished now, i've started to put things back on the car
i've bought a new universal waster bottle so i can relocate the washer bottle inside the car, to give me the room for my relay's and junction box
placed the templates on the bonnet now too, ready to cut them out ;)
bren_1.3
hmmm any pictures of the universal washer bottle? im about to do the same but was using the original washer bottle instead. if its a neater solution than mine ill copy what youve done?
Spiky
I'm going to fit mine either in the passenger footwell, or in the passenger rear qtr
here is what i bought, i'll get more pics later if you want???
it came with pump, pipe, button to use it (but not needed as i will run with the OE wiring
