Spiky
[trackday_prep] My 205 GTI-6 Supercharged Track Car
Daxed
Is the fan mounted directly to the radiator face using the plastic fixings (similar to cable ties)? - Don't know what others experience of these is, but I mounted a fan using the supplied fixings and over the period of a few months the vibration of the fan in use caused it to wear it's way through a water channel and hole the rad.
Ended up fabricating some proper mounts.
Spiky
yes they are, mounted as you say
mmm maybe i may re-think this then :D
Spiky
ok decided to finish the brake lines tonight :angry:
fuel sysem next, though i only need to connec the pipes to the intank pump and tighten all fittings then flush the system through
Powers
You have been busy!
Not far off from running then, just the diff and gearbox left.
309PUG
Make sure you cusion the battery, if it's a small red top racing gell type they don't like a lot of vibration, so pack the underneathe with some foam or similar.
Chris
Spiky
Chris
ok will do :D:):D
MrG
this is looking good, any idea when you're first outing will be?
Spiky
bedford 2nd of february :)
then donnington end of feb
then a whole load more events :P
All Praise The GTI
the build is looking good mate. if all goes to plan my conversion will completed shortly and maybe ill see you at bedford.
whats the track like there?
MrG
Bedford eh! Well I may just drop by for a watch.
Dave G
looks good mate, has come along way
Spiky
bedford is a great track, only one place which has a wall :)
great for learning a new car setup :)
ashley peddle
bedford 2nd of february :lol:
then a whole load more events :rolleyes:
shame - im there on 26th jan :blink:
Spiky
finally got back to working on the car after a xmas break, well work on the house :)
not much, progress but really happy that all the fuel fittings in the car are now finished and it's just the engine bay fuel system that needs doing :blink::lol:
both pumps are wired up now with their own fuse and relay's :lol:
hopefully more done this weekend :lol:
Discostu
Looking good matey :P
Spiky
done some more work on the car
car is looking a bit more what it should do
my new reno clio oil filter, means i can do an oil change with the rad in place..lol
fuel lines now secure
fuel rail now all fitted
then :) :), i pressured the fuel system to check for leaks, and had a bloody leak B)
my fault too, i nipped the ruber seal on the injector :( so will order some new one's tomorrow
and made a new straight peice for the water pipe, from my old washing line....pmsl
Powers
Stainless steel rubber lined P clips! Christ I though I was fussy and how much!!!! lol!
Looking good though dude. Almost there.
got tons of those P clips in stock in work :) you haven't painted the engine though!!
I did :):)
Spiky
i'm not..lol
it's staying there until i break it ...
Spiky
the last part of the jigsaw turned up today
well parcel 1 of 2, and i bet you can probably guess whats in parcel 2...lol
Edp
Looking good!
Which clio is the smaller filter from?
Edited by Edp
Garry
Looking good!
I would have thought its one of the 1.8 16v ones, R19 16v too. Thats what I use.
Keep going Spiky, you are very good as a development mule! We are going to end up with nigh on identical cars soon, that is when I have copied all of your ideas :D
Spiky
yeah garry right, went and bought and i quote" please can i have a oil filter for a 1.8 16v clio from around the n reg ...lol"
and thats what i got :)
hay garry, this is an expensive mule..pmsl
what stage you at with yours??
more goodies coming tomorrow too :wub:
