Spiky
[trackday_prep] My 205 GTI-6 Supercharged Track Car
Batfink
very easy to box off there so you might as well!
Spiky
Never taken the pug to pod, and fancied a run up the strip
So yesterday it had 3 runs up the strip
It survived the day fine :)
But I was only launching at 3000 revs
Here is the vid from run 3 my quickest time
12.88 @112mph
Here is my timing sheet
37418A4E-6C2B-4D53-B709-B69E50C28C24-106
Spiky
Henry 1.9GTi
very quick! nice one. Good job on the fuel side as well. How is the seat clearance?
I managed ok with hardline in the end. No leaks yet, touch wood, and was relatively cheap. But not having fuel surge is friggin awesome! haha can start with 1/2 tank in quali now rather than filling it right up the filler neck :)
Spiky
cheers,
clearenace is fine, but i am short :)
nice one on hard lines, did you use -6 (an6) teflon lined?
no fuel surge is a great thing,
i've been on track, carried away playing with a cateram and noticed the fule light on, no issue though :)
Henry 1.9GTi
indeed, I think my fuel gauge was reading empty for last half of race, but once stopped returned to 1/3 :)
Hardlines are standard Peugeot under floor steel fuel lines. I then ran out of this so got some Aluminium hardline off demon tweeks which was much easier to bend! All 8mm OD. Grommet'd through the floor down the side of the tank as per original flexi lines, and grommet'd through floor to the OEM pump. I have double clipped everything with stainless fuel hose clips and the swirl pot / 2ndary pump are boxed with sealing glands used for the fuel pipes into the box. I was a little dubious of my own efforts at first but I think with only 3bar fuel pressure it should be ok. Flexi fuel hose under car and in the box is just braided rubber 8mm ID hose. No smell, no surge, no leaks, and straight through scrutineering. Will be keeping a close eye on it though!
TT205
Did you ever go up to the high boost conversion?
Spiky
Henry, sounds like a result then:)
Tt205, no still std low boost setup
Spiky
car has been running great with the charger, except when flat out on track, the water temps rise and stabilse around 95-100
normally it used to be 80
i've put it down the fact the intercooler is twice and thick as rad and is slight bigger, and fitted right in front of it,
so to test this theroy, i bought a 2wd cosworth intercooler to see if that helps
as the intercooler is now above the rad, so nothing infront of the rad anymore
see pic's
would probably benefit from some simple sheet steel or plastic cowlings, air takes path of least resistance of course.
allye
Surely your inlet temps will rise dramatically now?
Spiky
WP, yeah, thought about this, and probably need it
allye, any reason? superchargers dont generate the same temps as turbo's, plus this intercooler is known for being effiencent at cooling, and is probably better than the "low boost" intercooler i should have been running, as i was running the high boost cooler
i will be fitting some cowling to allow cold air to the ait filter, or maybe place the air filter somewhere else
allye
Ah right, learn something new!
Spiky
I didn't want to worry about the go pro battery going flat so, solved that issue :)
62A4E084-5AB7-4D4D-BC49-68A1C84F62FF-529
rallyeash
I'm going to do the same for my go pro!
Spiky
cool, saves worrying about battery life
i bought a new case (cheap ebahy ones, £12) and drilled a hole in the side
so use my genuine case on the outside of the car, took a vid stuck on the lower part of my door, , takes a cool vid, sadly cant show on here..lol
Spiky
We'll after 7 years , well will be on the 1st of jan, I've decide to sell the 205
Mainly as I have no time and money to do lots of track days each year
Sadly there is no point me advertising complete as no one is going to give me the same as I can from breaking (around 8k)
So. Soon I will be advertising the parts for sale, the whole car will be for sale
No dibs, first to pay gets it :)
Bring on my next car, which I will track :), a E46 m3 with smg gearbox
rallyeash
Oh man! That's a shame. Now is there anything I should be buying from you?!
allye
Massive shame spikey. And a loss to the scene I would say. I hope you keep your finger in the 205 pie in one way or another though.
Spiky
cheers lads, have enjoyed the whole building of a track car, the way i wanted it,
i'll still be around, i still make the looms for people :)
ash you car is higher spec than mine, not sure there anything on mine you need?
chipstick
Sorry to hear that Steve (whilst rubbing my palms together). There's a few bits of interest to me so I look forward to your breaking thread.
Spiky
charger?....lol
S@m
Have you driven the A4059 from Hirwaun through Penderyn over to the beacons road lately? Thought i saw this car one night a few weeks back, i was in a silver GTI. Shame its being broken.
Spiky
Not in the 205 no
GilesW
Just read your whole build thread.
Shame to break it as it looks like you've developed it well, and guess the car has kind of 'grown' with you.
However I've been there - only way to get decent money is to break it.
If you do of course I'll help you by buying the boot lid etc off you. lol.
