s16 Peggy
How To Shorten A Throttle Cable?
s16 Peggy
Hi all,
I have just completed the conversion from my S16 inlet manifold to the GTI-6 one, and I am going to need to make the throttle cable shorter.
Has anyone any good tips for doing this with minimum hassle?
Nigel
sonofsam
I had to shorten a 405 cable to fit on my 205 turbo, would suggest a really good pair of cutters
as not to mangle the cable, and the outer black cable wich has the spring embedded in it( much like a bycycle cable )I used a junior hacksaw on, with no much bother at all.
s16 Peggy
Thanks,
Whats the best way to reattach the nipple for the butterfly though?
sonofsam
Sorry cant help there, mine had a little metal dowl with a grub screw.
Alastairh
When i do mi conversions i just buy a new cable off a 405 from pug, its adjustable to what ever length you want.
Alastair
s16 Peggy
Alastair
Thanks very much. Thats what I shall do then.
what you need is the little barrel with a hole through it and a screw in from the end, best way I can desrribe it! comes on 306 diesel throttle cables, and I know that the bikeshop i used to work in has hundreds of them in the workshop, I could get one for you if thats easier than getting a new cable?
(which IIRC would be a lot easier to shorten the current unit than fit another one, buggers to do!)
s16 Peggy
Cheers,
I might see if I can rob one off my mountain bike :P
