Rupertfinch 6 Posted January 30, 2007 Had the old girl up on a hydraulic ramp last week (1991 1.6) while replacing rear shocks. Anyway, while running around underneath her doing the old 'WD40 it to within an inch of it life' routine, I noticed that the flywheel was winking at me, leading me to conclude that I was missing a flywheel cover - there appears to be fixing holes for such a thing. 1. Should I have one in the first place? 2. Could I ballax everything if I don't get one quick? 3. Anyone got one for sale? 4. Exactly where is Lord Lucan? Share this post Link to post Share on other sites
Alastairh 47 Posted January 30, 2007 1. Yeah you ought to. 2. Potentially yes. 3. Maybe, i'll have a look in the garage. But i know 205parts.com has plenty on the shelf if need be. 4. Out the door, turn right, past the trees, 18 large steps and down the drain cover Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted January 30, 2007 Can't see it being a huge problem to be missing it but better safe than sorry I guess. Should be plenty around, post a wanted ad and I'm sure you'll find someone with one lying around. Rob Share this post Link to post Share on other sites
Rupertfinch 6 Posted January 30, 2007 Thank you for your help gentlemen. Now as to the whereabouts of Shergar...? Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted January 31, 2007 I don't run one mine without any issues, there isn't a very big gap for it to let anything in & it also allows any oil or water that gets inside to drain away faster / easier. When I had the alloy sump fitted I couldn't get it back in so I left it off since, even though I have now swapped back to a tin sump. Shergar is all over the place, dotted around schools in various glue pots. Graham. Share this post Link to post Share on other sites
taylorspug 7 Posted February 1, 2007 All ive found those guard things to do is trap oil from weeping crank seals etc (as Graham has mentioned), which then ends up getting spat everywhere by the flywheel and contaminating the clutch. I certainly havent run one for the last year, and ive had no problems at all. Share this post Link to post Share on other sites
