huzzer 0 Posted January 29, 2007 I am currently fitting an Mi into a phase1 1.6 and am having trouble wiring it in. All the info available on here (diagrams etc.) seem to refer to phase2's. I have a loom that has already been fitted into a 205 (motronic, plug and play) But none of the connectors seem to correspond to anything in my car! Do I need to make up a new link loom, and if so does anybody have any diagrams for this? I would still like to have all the gauges working. Cheers. Share this post Link to post Share on other sites
jackherer 543 Posted January 29, 2007 Earlier models have the dash wiring on the passenger side inner wing, seperated from the main engine loom. You should be able to hook it up to the Mi16 just like an 8v, and then ignore the wiring that came with the Mi16. Share this post Link to post Share on other sites
welshpug 1,657 Posted January 29, 2007 phase 1 differed from the 1.5, then the coils were relocated to the intake manifold early phase 2, then different management were introduced but I dont think there was much in the way of changes bar the O2 sensor wiring from then on. Share this post Link to post Share on other sites
huzzer 0 Posted January 29, 2007 Thanks guys. Jackherer, are you saying that after the reverse switch on the 405 loom I dont need to connect up anything inside the bulkhead? Which sensors will i be connecting to with the 8v? I've got two black connectors coming through the bulkhead on the passenger side (1x 9pin and 1x 6 pin that only has 4 wires in it) Can i just not connect these to anything? Share this post Link to post Share on other sites
pug_ham 244 3 Cars Posted January 30, 2007 I've got two black connectors coming through the bulkhead on the passenger side (1x 9pin and 1x 6 pin that only has 4 wires in it) Can i just not connect these to anything?Are these from the 405 donor? If they are then you don't need the majority of the wires in them. Use the sensor & reversing light wires from your original 205 loom & find the wires needed in the 405 loom to splice to the wire in your 205. In total there are four or five wires needed. (2, 32a, 76, 112 & 74 for the K light but that needs a bit more work to wire in on an older 205 such as yours). Graham. Share this post Link to post Share on other sites
