djinuk 2 Posted January 29, 2007 ok i have a 1.4 pug 205 xs, and the fuel is not reading , ive put £25 in and its not budged its stuck on red with the light on. can anybody instruct me on how exactly to sort this problem out. kind regards damian Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted January 29, 2007 Short the guage out to see if its the sender or guage thats dead. The sender is under the righthand rear seat base under the smaller of the two plastic covers (if they are still fitted). To test it, remove the plug & bridge across pins on it. The plug is a three pin one, one wire should be green which is the earth. Bridge from the middle pin to that one, switch the ignition on & it should go full scale if its the sender thats dead. The two outer pins should put the low fuel light on. If the guage works all OK then you need to remove the sender & replace it with a new one. Graham. Share this post Link to post Share on other sites
djinuk 2 Posted January 30, 2007 ok , done that all is fine, so its the sender.. how do i remove the sender unit from the fuel tank exactly ? Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted January 31, 2007 Read the haynes manual? Removal 1 Disconnect the battery negative lead. 2 Raise the rear seat cushion. 3 Remove the circular plastic cover to expose the sender unit (see illustrations). 4 Disconnect the electrical lead. 5 Using a suitable tool, unscrew the sender unit mounting plate to release it from the securing tabs. 6 Withdraw the sender unit, taking care not to damage the float as it passes through the hole in the tank. Refitting 7 Refitting is a reversal of removal, but use a new sealing ring if there is any doubt about the condition of the original one. Graham. Share this post Link to post Share on other sites
djinuk 2 Posted January 31, 2007 cheers , got a haynes manual on order Share this post Link to post Share on other sites
