chris1986
Bottom Arm Bolts
chris1986
i'm having trouble getting the correct arm bolts from peugeot i'm after the front one, but for some reason the one they sent was the back one (the bigger one) and a fully threaded front one where as the old one had a shoulder like the rear one, the dealers say this is the right one they have sent but im not sure. i havnt got the part no on me but if any one knows which is the right one it would help alot
thanks
jonnie205
A fully threded one is not right, why not just place a wanted add for a used one as pug always supply the wrong bolts
Try a different dealer, or even Citroen, they might have some suitable bolts in stock.
failing that take your old bolt to a fastener stockist and get some high tensile bolts of the correct dimensions and a nyloc nut :ph34r: will end up cheaper than a stealer :lol:
jonah
A fully threaded one will work just fine. Why wouldn't it?
