Guest Andyo_123
Twin 40s
Guest Andyo_123
Hi ive just bought twin 40s for my 1.9 8v but i have powersteering, does anybody have a guide to fitting them, or can you buy a bracket for the alternator and p/s pump.
Thanks Alot Andy
cybernck
check the articles on the main website :(.
boombang
You have the option of either losing the power steering or fitting an electric PAS pump, such a 106 Gti.
Check the main site as suggested for the articles...
Guest Andyo_123
would i be able to buy the bracket that fits the ones without powersteering and fit the carbs right on.
Cheers Andy
j_turnell
You can just modify the bracket to retain the power steering.
Guest Andyo_123
if i was to loose the powersteering would i have to buy another steering rack?
Thanks Andy
Edited by Andyo_123
Ryan
No you can keep the steering rack, just remove the pump and all the pipework for it.
You should also remove the hydraulic ram from the rack itself as otherwise it's technically an MOT failure, but it depends on the person doing the testing whether or not they pick up on it.
