boldy205
Beam Mounts
boldy205
hi, i was wondering if fitting the 'front' beam mounts (the clyindrical ones) the wrong way would have any impact on the camber of the wheel, as the Haynes book of lies says to put the cut out part or the bush facing either up or down. i cant see it myself but its just a thought. wondered if anyone had done this?
Thanks.
Matt.
Edited by boldy205
mi16nut
I'm no expert,but I wold say absolutely not.
The only things to cause negative camber will be a bent stub axle or more likely knackered beam bearings.
boldy205
the bearings are new, all up to scratch, stub axle has been changed, so im thinking bent trailing arm? the bushes were just a bit of a guess, thought maybe someone may have said, 'oh yes, i done that once!'
thanks anyway. :(
taylorspug
How much camber are we talking about here? Is it possible you just have, say, one Citroen ZX trailing arm, as these run more camber as standard.
boldy205
to my knowlage their both 309 arms. just wondering about the bushes really, as at the moment it would not be to bad a job to turn them around . thanks anyway! (camber wise its got about 0.4 on the 'good' offside and about 1.6 on the bad nearside.)
Matt
Edited by boldy205
