Boris 0 Posted January 20, 2007 look at this video and can anyone tell me why? 205 low rpm It's like breathing on the low and no stops! this is new! Can this engine sensor on the choke control must be the problem? Share this post Link to post Share on other sites
Guest srack Posted January 20, 2007 your problems arent on a cold start i assume. so the problems can be 1: afm problems. try replacing or check the wires. 2: vacuum problems. 3: injectors that sensor you showed is incharge of a cold start issue. so that wont be your problem if you ask me, its one of the first 2. Share this post Link to post Share on other sites
Boris 0 Posted January 20, 2007 I have changed the AFM with other but no result.the same... the vacuum and injestors are OK . Share this post Link to post Share on other sites
Richie-Van-GTi 73 2 Cars Posted January 20, 2007 air leak on the intake,check the plenum for air leaks including the bolt that holds oil filler neck in place Share this post Link to post Share on other sites
Boris 0 Posted January 24, 2007 the bolt that holds oil filler neck is ok.i know about that.. but no air leak on the intake, I'v cheked everything... 1-problem in AFM 2-worn out camshaft Share this post Link to post Share on other sites
