Boris
Problem With The Low Rpm
Boris
look at this video and can anyone tell me why?
205 low rpm
It's like breathing on the low and no stops!
Pics04.jpg this is new!
Can this engine sensor on the choke control must be the problem?
Guest srack
your problems arent on a cold start i assume.
so the problems can be
1: afm problems. try replacing or check the wires.
2: vacuum problems.
3: injectors
that sensor you showed is incharge of a cold start issue. so that wont be your problem
if you ask me, its one of the first 2.
Boris
I have changed the AFM with other but no result.the same...
the vacuum and injestors are OK .
Richie-Van-GTi
air leak on the intake,check the plenum for air leaks including the bolt that holds oil filler neck in place
Boris
the bolt that holds oil filler neck is ok.i know about that.. but no air leak on the intake, I'v cheked everything...
1-problem in AFM
2-worn out camshaft
