Guest BrainFluid Posted January 19, 2007 Seen as its the negative that you should disconnect when working on the car do they put the easy twist off connecting terminal on the positive feed? Weirdos! Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted January 20, 2007 hmm it's negative off when you want to reset the ECU, but i always take a positive off if i'm working on electrics . Share this post Link to post Share on other sites
petert 601 Posted January 20, 2007 I always take the negative off a car battery. That way if a tool accidently branches the positive terminal (or starter, alternator etc.) to earth, it won't cause a big SPARK! Share this post Link to post Share on other sites
t16ryan 1 Posted January 20, 2007 Seen as its the negative that you should disconnect when working on the car do they put the easy twist off connecting terminal on the positive feed? Weirdos! lol it is the negative with the quick release terminal ? Share this post Link to post Share on other sites
Guest BrainFluid Posted January 20, 2007 lol it is the negative with the quick release terminal Haha, your right Ryan it not is it. I'm a moron...Dont worry I'll get over it. Why on earth was I thinking that today then.....? Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted January 20, 2007 petert> yeah that's a good point , but i was referring to working on a fuel pump etc. i disconnect positive or both in that case. Share this post Link to post Share on other sites
Sam 4 Posted January 20, 2007 Surely it makes no difference, after all there is no circuit if the negative is off. Share this post Link to post Share on other sites
Jer309GTi 3 Posted January 20, 2007 I always take the negative off a car battery. That way if a tool accidently branches the positive terminal (or starter, alternator etc.) to earth, it won't cause a big SPARK! Thats the way they taught us at college, and for the same reason, disconnect first-reconnect last Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted January 20, 2007 I always take the negative off a car battery. That way if a tool accidently branches the positive terminal (or starter, alternator etc.) to earth, it won't cause a big SPARK! Thats what they recommend for every job in the Haynes manual; Changing a tyre; 1. Remove battery negative lead. 2. Loosen wheel nuts/ bolts slighty 3. etc... Even changing a fuse I bet. Graham. Share this post Link to post Share on other sites
