pugbliss 0 Posted January 19, 2007 I need major help as i carnt find my pins on the hinge. im assumng that they go down the little shaft?????? or are they the whole shaft that is part of the hinge??? ive not got a punch yet but when i stick a screwdriver (crude i know) i carnt feel any ridge of a pin down there? Share this post Link to post Share on other sites
KRISKARRERA 2 1 Cars Posted January 19, 2007 Might be a good idea if I point something out here - that pic is of my car and it's a 405 with the torx headed pins. Share this post Link to post Share on other sites
pugbliss 0 Posted January 19, 2007 yeh i know soor but i dont have a camra and had to search for a pic..hope you dont mind. but the jist is still there Share this post Link to post Share on other sites
KRISKARRERA 2 1 Cars Posted January 19, 2007 No that's ok I was just worried you thought that was a shot of a 205 hinge. Share this post Link to post Share on other sites
pugbliss 0 Posted January 20, 2007 no i know that ...but cheers anyway... does anyone know the answer to my question???? please Share this post Link to post Share on other sites
KRISKARRERA 2 1 Cars Posted January 20, 2007 Well I would answer only I've not got a 205 to look at Share this post Link to post Share on other sites
welshpug 1,675 Posted January 20, 2007 to do the job properly you need this tool - the pins are in the same place as the bolt in the picture above. about 7.5m in diameter IIRC. If there arent any pins your door would fall off Share this post Link to post Share on other sites
Paintguy 0 Posted January 20, 2007 They may not be pins as such - i.e. not a solid pins as you might expect, but a kind of hollow split tube, known as a roll pin. A bit like this: Share this post Link to post Share on other sites
pugbliss 0 Posted January 23, 2007 oh i see,,,,,, Mmmmmm i think i get ya does anyone know the diamiter of the pins??? cheers Share this post Link to post Share on other sites
mossy 0 Posted January 23, 2007 7 mm if I remeber correctly Al. Share this post Link to post Share on other sites
jonnie205 1 Posted January 23, 2007 What age is your 205? post 91 cars have bolt in pins rather than roll pins. Share this post Link to post Share on other sites
pugbliss 0 Posted January 24, 2007 my 205 is a 1990 and im sure it has pins as there are no bolts to be seen Share this post Link to post Share on other sites
Simes 248 2 Cars Posted January 24, 2007 my 205 is a 1990 and im sure it has pins as there are no bolts to be seen yours will have those in the pic. They may have a plastic cap over them to stop water ingess. to do the job properly you need this tool - What is that tool? Psrt no. etc etc... Share this post Link to post Share on other sites
welshpug 1,675 Posted January 24, 2007 draper stock number is 54585. got them for £12.17. oh, and it says on the packaging in the pic Door pin removal kit Share this post Link to post Share on other sites
Guest rick03054 Posted January 24, 2007 draper door pin removal kit here. Share this post Link to post Share on other sites
welshpug 1,675 Posted January 24, 2007 thats the one Share this post Link to post Share on other sites
Simes 248 2 Cars Posted January 25, 2007 Thanks Cheaper here http://www.abbeypowertools.co.uk/car-repai...witem-5554.aspx Bought one! Share this post Link to post Share on other sites
kaich 6 1 Cars Posted October 28, 2007 (edited) to do the job properly you need this tool - <!--ImageUrlBegin--><!--ImageUrlEBegin--><!--ImageUrlEnd--><!--ImageUrlEEnd--> the pins are in the same place as the bolt in the picture above. about 7.5m in diameter IIRC. If there arent any pins your door would fall off how does this tool works? cheers Edited October 28, 2007 by kaich Share this post Link to post Share on other sites
