matty_gti
1.1 Water Drain Plug...
matty_gti
As in the title, im in the process of changing the cam belt and water pump on my 1.1 TU but can find the water drain plug????
Rippthrough
I just undo the one on the bottom of the radiator - but there's a (17/19mm) bolt right on the front of the block to the right of the downpipe if that's what you're after.
Jer309GTi
If not just take off the bottom hose and drain it that way. Does the job ;)
