pugbender
Standard Fuel Pump On A Carb Conversion
pugbender
hi guys, i'd like to know the reasons why the standard fuel pump of a 1.6 gti can't be used with a carb conversion? perhaps the flow is higher than a facet fuel pump?how many liter for minutes(or gallons) does it has to pump?
m.i-man
It's the pressure that needs regulating. You need to drop the psi down to around 3-5....
You can either use your existing pump with a couple of adjustable fuel pressure regulators to drop the pressure. Or rip the old pump out, and fit a low pressure red top or something with an adjustable fuel pressure regulator also!
pugbender
thank you mi man so the solutions are:
- installing a fuel pressure regulator with 1 entrance and 2 exits before the entrance of the carbs with the std fuel pump;
- replace the old pump with a low pressure ones
but I was thinking..:the pressure of the std pump is due to the snd fuel pressure regulator so eliminating only the fuel pressure regulator the pressure will be less..so the rel problem is the flow:
how many litre for minutes has the std fuel pump compared to a facet pump ones?
hodgy
i un plugged the standard pump and fitted a facet silver top in the engine bay and lowerd the pressure to 2.5 psi with a filter king. if u leave the standard pump running it will jst fire fuel straight out the carbs and all over the engine like it did with mine!
i used a Facet silver top pump, filter king regulator
hodgy
a standard fuel pump is bout 70psi and the facet is 2-5 psi
pdd144c
And then it should catch on fire in no time at all!
m.i-man
I don't see how, as most of the fuel will be returned to the tank? :D
ashley peddle
only if you fit them poorly :D
andy0075
hi,
the original fuel pump of the XU9JA / XU9JAZ ( 1.9L 128PS/120PS ) pumps 130 liter per hour. That is the same as
the FACET SILVER TOP. The FACET RED TOP does 158 liter per hour.
If you would use the original pump with carbs, maybe you can take this. Found it on Ebay.
http://cgi.ebay.de/FUEL-PRESSURE-REGULATOR...oQQcmdZViewItem
Edited by andy0075
ashley peddle
that is a turbo regulator... will only take the pressure down to about 5... you then need an adjustable regulator to change it between 1 and 5... :D mine is currently set to 3.5
andy0075
Do you drive an 8V or 16V ? What carbs do you use 40's or 45's ?
I actually build up a 8V 205GTI with carbs, and i don't know
if it is worth to buy 45 carbs because of the much higher price
compared to the 40's. I have already an good flowed head, a middle hot
cam (280°, max lift 11,5mm) and a cr of 10,5:1.
Someone told me i should use a chokesize of 36mm with 45 carbs, but the
36mm chokes will also fit in the 40's . So, what is the advantage of the 45 carbs ?
pugbender
It's an 8v 1.6 with a 300° duration camshaft lift 11.5 (It's a french ones) ported head, home made intake manifold with 40's solex ddhe, 32mm chokes, 500gr off the flywheel and lightened front pulley.
andy0075
32mm chokes sounds very small ? but i have no experience in
practice, i just read a lot ;-)
I try the 36mm chokes when i bring the car back to life in one
or two month. But actually i dont know in what carb.
40mm or 45mm....grrrrr...
pugbender
probably 32mm chokes is too small but I'd like anyway to done a test, I imagine that a smaller chokes significe better low and middle throttle response, i read in the forum that a boy used a 40mm chokes in his 45's but when he put 36mm chokes he lost only 2bhp in top end power but he gained a better mid range response;
so 32mm on 40's probablt there arn't too small like they seems to be!
mfield
http://en.wikipedia.org/wiki/Venturi ;)
pugbender
well, anybody have the electric circuit of a 205 1.6 gti I realy nedd it!I should do tomorrow a direct circuit to swith on the fuel pump!thk U
