Guest markiboy2007
Where To Get Glovebox?
Guest markiboy2007
hi guys
checked local breakers and ebay but still to no avail, any ideas as to whre i can get a replacement glovebox for my 205 ??
sutol
Do you just need the box/drawer or whatever is called , because I'm breaking a 'K' plate TD.?
Guest markiboy2007
emm i dunno mate just the whole glove box mine is missing entirely, is it a black glove box in the td?
sutol
Back yes, ....someone should know about glove boxes and let us know the following;-
Are they all the same or did the different phases have different shapes. ?
Guest markiboy2007
ok mate how much do u want for it if we find out that it fits??
thanks for helping out by the way!
and its a phase 1 i have, G plate
sutol
Let's check it fits first and then a tenner posted done and dusted.
Glad to help out
Guest markiboy2007
Glad to help out
top guy, well ill keep an eye on the thread and hopefully someone will let us know, then we can sort out payment, thanks again!
Sutols is K plate that'll be black not grey,
markiboy's car is most likely to be phase 1.5 so it will fit, but not the right colour
Guest markiboy2007
i thought my interior was black lol ill have a look tomorro!
Blatant wanted ad!!
No point removing now as he appears to be sorted with one from sutol.
GLPoomobile
There is quite an obvious difference between grey trim and black trim, once you have seen both!
What year and reg is your car?
Guest markiboy2007
its a 1989 G plate!
GLPoomobile
its a 1989 G plate!
Oh, fairly likely to be a proper PH 1.5 then with the grey trim. Mine is a 90 H and is a kind of a Ph 1.75 :) - mostly Ph2 bits but with the odd Ph1 bit here and there - and it has black trim.
I've also got a spare glovebox but it is black.
Guest markiboy2007
Oh, fairly likely to be a proper PH 1.5 then with the grey trim. Mine is a 90 H and is a kind of a Ph 1.75 :P - mostly Ph2 bits but with the odd Ph1 bit here and there - and it has black trim.
ok thanks for the advice :)
