chris1986
Clutch Upgrade
chris1986
have dine a few searches but still need to ask,
what clutches are you lot running in the 1.9s as i'm going to be putting a new enine in soon and it would be silly to not put a new clutch in, its main;y going to be for hill climbs and trsck dsys with s few miles on the road. i was thinking sbout the helix range, does over £250 sound right for a new helix one. i've been put off by everyone that s had a techni clutch put in not just 205's.
TEKNOPUG
Yes, I'd go with an organic helix GrpN clutch, about £250-£300.
Probably not worth it though if you are not runnig considerably more power.
A cheaper fix would be to use an Mi16 flywheel (215mm) and then use a standard 215mm clutch for less than £100
chris1986
i might consider the mi16 fly wheel. if anyone has the correct part no for the helix clutch for a 1.9 it would be great if you could give it to me.
are the cluctches the same for 1.6 & 1.9?
jonnie205
A standard valeo 8v clucth will be fine. I am runnning an 1.6 8v flywheel on an mi16 with 200bhp and it spot on. Uprated clucthes only realy needed for mega power
TEKNOPUG
This is true - it's torque that kills clutches, not "power".
chris1986
well i think this engine will be standard, and i guess if you at that power on a normal clutch then theres no point really. looks like it will probably be a luk or valeo then, jonnie do you use your care out on track or just on roads?
whizzer71
Personally I would go for Mi at least if competing in motorsport,used to do time trialing,and the Mi clutch was the only pull type that didnt let go,(never tried the push variety though Gti 6 etc)
:D
jonnie205
its the pull that are gti6 not push. My car is used on track and road and it gets a very very hard time. Uprated clutches are ok if you plan on animal standing starts etc but they are very hard on the drivetrain.
chris1986
thanks you've probs just saved me over £200
whizzer71
Yeah sorry guys I was reffering to the operation of the clutch cable :D ,Now realised that obviously it relates to the method of disengagement !
Rik
NEVER EVER EVER go to Techni Clutch!
There standard clutches painted red! the guy lives and owns a garage near me, everyong round here knows there just standard cluthes!
Terrible though he must still be making a profit - he got a Bentley!
Rik
Jez G
Clutches are specified by torque capacity in Nm (or ft.lb in old money). The more torque you have (combined with gearing) will mean longer slip times, this is what kills the clutch.
Power 'ps' or 'BHP' has absolutly nothing to do with it.
Jez
