Guest justinhincks87 Posted January 16, 2007 Hi there is there anyway i can check if my fuel relay is not workin. as i have no fuel. when i turn the key and ignition is on. there is no noise from fuel pump or a click from relay . any way i can check whether the relayh works before i go out and buy one for 46 pounds!! cheers Share this post Link to post Share on other sites
hengti 2 Posted January 16, 2007 i'm going through this at the moment too and have just, today, condemned my fuel pump you can check the tachymetric relay by disconnecting the leads that go into the fuel pump (white is positive and green is negative [i'm assuming you've got the model with the fuel pump under the rear seats]) and, running a length of wire from each connection, attach the leads to a bulb. crank the engine - if the bulb lights, the fuel pump is receiving a current and the tachy relay is likely ok. you could use a multimeter if you've got one. then you can check the fuel pump by running leads directly from the battery. hope that helps diagnose the problem anyway this is probably of little additional use, but i can confirm that there are no 205GTi fuel pumps in any of Bristol's breaker yards! Share this post Link to post Share on other sites
Guest justinhincks87 Posted January 17, 2007 the fuel pump works. i cannot hear a click on the relay when i turn the ignition on. Share this post Link to post Share on other sites
hengti 2 Posted January 17, 2007 if you're sure the fuel pump works, that part of the function of the tachy relay must be ok. i believe that it also controls the injectors, although i'm not sure how you'd test that part of its function. you could try wading through the info on search if no-one else offers. sorry - can't help beyond that. Share this post Link to post Share on other sites
Ahl 4 Posted January 17, 2007 You can also just stick a couple of bits of wire into the right terminals on the relay socket. It'll then operate the fuel pump and injection system continuously. Not good to drive with, but it'll let you know if the relay is gone. Search for 'tachymetric relay' and you'll find the wire numbers that you need to bridge. Share this post Link to post Share on other sites
