acox99
High Performance Big End Shells
acox99
I have searched the forum and the net, and i cant find any high performance bearing sets for the MI, i want something thats going to take a lot of stick, and constant high reving, the last thing you want to do is spin a shell. Can anyone help
Ali and Alan
Ahl
Have a read of this post
Sie
1.9 GTI are the same bearing as the XUD9 , K.S part No 77097608 .
No heavy duty lead copper or silicone bearings have ever really been available as the standard material is good enough to cope . Only a few bearing manufacturers produce these bearings so whatever bearings you buy will be a good quality bearing . Hope this helps
acox99
ok cheers for the advice standard bearings it is then, do you recommend you replace them every season?
Sie
Ah just re-read you first post , MI bearings are NOT that part No . I would check them at the end of the season because if there is no excessive wear then the extra clearance between the crank and the bearing will give an extra thou of so of clearance to allow more oil in contact with the opposing surfaces and produce less friction .
Longmans sell a lead based big end bearing but only in a std size, but again I have always used the std bearing's and never really had too many problems, The main thing is to get the clearance right, What rod's are you using?
acox99
we've not decided what rods we're going to use yet, still trying to work out whats best without going too overboard. The standards are pretty good then? dont want to damage the crank if we're spending a lot of money on it as the aim is for the highest output we can get with money etc....
rescue dude
If it was me i'd change them every 250-300 miles.
You should have no problems if you do this.
pug309twin40s
:D:):o:o you missing an 0 of the end cause at that miles your be needing a bulk buy of bearings and car more of the road than on it changing them lol!!
James_R
unless he means stage miles for hillclimbs and sprints, they cover harldy any distance and have to have regular rebuilds.
