oli-pug 6 2 Cars Posted January 15, 2007 cannot believe it, i've managed to snap the bolt that connects the gear linkage arm to the subframe. god knows i managed to overtighten it is there anyway i can just replace the bolt itself, or do i need the whole linkage arm assembly back to the gearstick Share this post Link to post Share on other sites
davev 1 Posted January 15, 2007 is this the one with the 13mm nut on? the bar that moves when you move the gearstick side to side, NOT the L shape one. if it is then i was just messing with mine the other day, and i remember there being a clip that allows the part that bolts to the subframe to come off the actual gear link. Share this post Link to post Share on other sites
davev 1 Posted January 15, 2007 this page should help. im talking about no. 7 http://www.stuartmcguire.co.uk/pug/GB/205F/2/24A12A.HTM Share this post Link to post Share on other sites
oli-pug 6 2 Cars Posted January 15, 2007 yep thats the one mate, ill get down to pug tomorrow. i've managed to get that spring clip out but the bolt dosent want to budge out of its hole. it's in an awkward spot so cant get proper leverage really Share this post Link to post Share on other sites
pug_ham 244 3 Cars Posted January 16, 2007 If you've managed to shear that bolt you get to the nut underneath through the subframe, 13mm nut up inside the subframe & 14mm on the bottom of the pivot iirc. Graham. Share this post Link to post Share on other sites
t16ryan 1 Posted January 16, 2007 If its the ball and socket fitment you mean i think i haveone somewhere it happened to me few weeks ago while driving luckily a base model fitted as had one but have broken a gti and should have one somewhere Share this post Link to post Share on other sites
Miles 331 1 Cars Posted January 16, 2007 If you need the ball drop me a PM as I have loads of them from my Gear rod's which I don;t use Share this post Link to post Share on other sites
oli-pug 6 2 Cars Posted January 16, 2007 i ordered the parts in at my pug dealer today, only cost a couple of quid so dont worry guys Share this post Link to post Share on other sites
