Simon B 3 Posted January 14, 2007 Hello all... Ok we fit 309 wishbones and thus the 309 driveshafts which are a bit longer.... where does the extra length on the 309 drivers side driveshaft come from? What i am getting at is... I have got the outer half of the 309 drivers side driveshaft, and wanted to know if it will fit onto the 205 inner part and still give the increased length? Hope what im saying makes sense??????? Cheers!! Nigel B Share this post Link to post Share on other sites
Ahl 4 Posted January 14, 2007 Its the outer part - the inner part is the same length as the 205 item as the subframe, housing etc are the same. Be aware that not all driveshafts are interchangable this way though. They may not fit together. Share this post Link to post Share on other sites
Simon B 3 Posted January 15, 2007 Thanks Ahl I shall have a little play tomorrow then! I do have the inner part of the 309 shaft, but its seperate from the outer part and is also 10miles away!! I will play and see what happens! Cheers! Share this post Link to post Share on other sites
Guest Si B Posted January 15, 2007 --> QUOTE(Nigel B @ Jan 15 2007, 12:21 AM) <{POST_SNAPBACK}> Thanks Ahl I shall have a little play tomorrow then! I do have the inner part of the 309 shaft, but its seperate from the outer part and is also 10miles away!! I will play and see what happens! Cheers! That's the answer we wanted Ahl!!! Hopefully, as it saves me hoiking the inner driveshaft off my spare Mi16 engine / gearbox assembly! Looking forward to seeing how the 309 stuff changes my brother's car, as I'm planning to do the same on my own shortly. Si Share this post Link to post Share on other sites
