TaffyTim
Bakerbm 16v Waterpipes
TaffyTim
The pipes in the link below look very tempting:
http://www.bakerbm.com/other.php?data=schkit16
I have an oil/water cooler on my engine and in the notes at the bottom of the ad it says the kit is for use with non oil/water coolers.
I have sent an inquiry direct to the site but was wondering if anyone on here knew what the difference was with the pipes with and without the cooler.
ta
Tim
Edited by TaffyTim
Tim
Your water Heater (Heat exchanger (HE)) isn;t connected so these pipes will do the trick and get rid of a ribbed pattern one too,
But for the HE can be connected like the 309 GTi with a top hose with 2 long take off pipes to the block or the 205 HE which is also a remote oil filter that mount's on the front of the gearbox and again the top hoses has 2 take off but allot shorter, I think the main reason for not producing these is the cost of it.
TaffyTim
Ta Miles
