davev
Ignition Advance
davev
hi, im planing on having a little play with my dizzy as i think the car is set up for normal unleaded. ive done a search and i basicly know what to do with the advance procedure.
the question is. will advancing the ignition mess up my fueling?
a bit more info to help answers:
its an mi16(standard internals) with bike carbs running 8 valve jetronic ignition system and obvisually a dizzy converter. i had it on the rollers and it made rather low power and the guy said its running very slightly lean and i should try advancing the ignition(after i told him that the car runns the same on unleaded and super)
so the main thing holding me back from giving it a go, is im unsure if ill make it leaner or even mess the hole set up up.
any help much appreciated. dave.
Faz85
Advancing the dizzy wont make the car run any leaner, it will simply cause the spark plugs to fire sooner. If the dizzy is too far retarded, like the guy at the rollers is suggesting, then by advancing it you should be able to unlock a bit more power, but you should be aware that over doing it will cause your engine to pink.
Faz
Edited by Faz85
Faz85
I should probably add dave...that if you mark the dizzy location before you do it, then you cant really mess anything up as returning it to its current position will restore the previous ignition timing.
davev
cheers. i get the point about pinking and the dizzy is already has a big grove where someone has marked it(must have been blind or something :P ).
just to confirm i have saw two slightly different ways to set the ignition. 1 was just warm up car and adjust till it starts pinking then back off a little, the other was almost the same but said to take it for a drive and put it under load. foot down at 30 in 5th for example.
Faz85
There is a by the book figure for the timing, but a lot of people prefer timing by ear. As you have found, try advancing it a few degrees, then go for a spin and put some load on the engine (flooring in 5th gear at 30 is a good idea) then listen for pinking (sounds a bit like a metal rattle, or try and imagine a bike chain being dragged along the concrete) if it does pink, back it off a bit and your sorted.
Faz
davev
cheers ill try it tomaz. was gonna today but seacrhing took its time :P
