Trick
Catch Tank
Trick
when fitting one to an mi16 (carbs)...
i understand what pipes need to be fitted (i used the search function)..
but after looking under the car, the pipe that connects to cam cover to the block is not so straight forward...
the end at the block joins onto a some sort of T piece - assuming i have to blank that off if im taking the cam cover pipe direct to the catch tank?
If so, how do i blank it? im a novice remember...
309PUG
It sounds easy but you have to turn down a plug of some kind to fit into the hole and put a jubilee clip round, if you have no access to a lathe then perhaps a cut down bolt or anything of a sutable diameter to provide a snug fit.
Chris
