mossy
Afm
mossy
Hi all Just a quick one.
If you need a spare AFM you may get one from a FIAT UNO Turbo 1.4.
I know theres not may around but another source if you come across one in a scrappy.
Bosch part No 0280 202 109 applicable to pre cat 1.9 ONLY
Beware they will all be a red/brown colour!!
so are hard to spot.
Al.
futura
Al.
That's always good to know, thanks :unsure:
they wont necessarily be calibrated the same as a 205 one so I'd check the fuelling and get it reset if needed.
mossy
I've not got one but after researching using the Bosch part no, it appears they were fitted to the Uno turbo.
If they are different why is the same Manufacturers No used????
Just a thought????
Al.
