mossy 0 Posted January 10, 2007 Hi all Just a quick one. If you need a spare AFM you may get one from a FIAT UNO Turbo 1.4. I know theres not may around but another source if you come across one in a scrappy. Bosch part No 0280 202 109 applicable to pre cat 1.9 ONLY Beware they will all be a red/brown colour!! so are hard to spot. Al. Share this post Link to post Share on other sites
futura 3 Posted January 11, 2007 Hi all Just a quick one.If you need a spare AFM you may get one from a FIAT UNO Turbo 1.4. I know theres not may around but another source if you come across one in a scrappy. Bosch part No 0280 202 109 applicable to pre cat 1.9 ONLY Beware they will all be a red/brown colour!! so are hard to spot. Al. That's always good to know, thanks Share this post Link to post Share on other sites
jackherer 543 Posted January 11, 2007 they wont necessarily be calibrated the same as a 205 one so I'd check the fuelling and get it reset if needed. Share this post Link to post Share on other sites
mossy 0 Posted January 12, 2007 I've not got one but after researching using the Bosch part no, it appears they were fitted to the Uno turbo. If they are different why is the same Manufacturers No used???? Just a thought???? Al. Share this post Link to post Share on other sites
