oli-pug 6 2 Cars Posted January 9, 2007 i know there's loads of threads on 307 brakes already but i need some advice on a which of the two sizes to go for... My question is how much heavier is the 283mm setup over the 266? Mainly because i dont like the idea of all this increase in unsprung mass leading me into a ditch! Share this post Link to post Share on other sites
boldy205 75 Posted January 9, 2007 a lot of people dont see the real NEED to uprate to the larger of the two. the 266 is ample. On my pretty much Std 1.9 a set of std size ATE pads and disks (the grooved type, available from Euro Car Parts) gave me a good set up on road. tho when these wear out id prob uprate to 266 as you can keep the wheel weights on the inside of the wheel then. Matt. Share this post Link to post Share on other sites
Adnic69 0 Posted January 22, 2007 What about an MI on the smaller 266mm disc setup? I have 283mm discs and pads but bought 266mm setup calipers off ebay by mistake. Share this post Link to post Share on other sites
Anthony 1,003 Posted January 22, 2007 What about an MI on the smaller 266mm disc setup?I have 283mm discs and pads but bought 266mm setup calipers off ebay by mistake. 266 will still be plenty sufficient with an Mi, road or track. Pad choice is more important than the size of the disks. Share this post Link to post Share on other sites
Jrod 7 Posted February 11, 2007 (edited) Dragging this up a little but on the mainsite guide it says that they won't fit hubs off lesser models. Will the 283mm setup not fit onto base model hubs? Edited February 11, 2007 by Jrod Share this post Link to post Share on other sites
Anthony 1,003 Posted February 11, 2007 Will the 283mm setup not fit onto base model hubs? Base model hubs will accept any brake upgrade that 1.9 hubs will as they're the same offset (just the wheel bearing and splines that differ) so there's no reason that 307 brakes won't go straight onto base model hubs Share this post Link to post Share on other sites
Jrod 7 Posted February 12, 2007 Good. Now where's my credit card. Share this post Link to post Share on other sites
