huzzer 0 Posted January 9, 2007 I am currently converting a 1.6 to an MI16. The donor engine came with the loom chopped out of the car and no ECU, so I have no reference to which loom and ECU I need? (I will be using the motronic loom)Does my engine need a specific loom eg. 1.3 Motronic or different? Can the engine number be used to identify this and where is the number stamped? Any help would be most appreciated. Thanks, Ben. Share this post Link to post Share on other sites
Baz 421 Posted January 9, 2007 Look at the ECU plug, if there's 2 or 3 rows of connectors that will pretty much define what ECU you need. Share this post Link to post Share on other sites
huzzer 0 Posted January 9, 2007 Hi Barry, There is no ECU with the engine as the loom had been chopped out of the car crudely, so no connector with it. Are you still selling a loom and ECU? Cheers, Ben. Share this post Link to post Share on other sites
welshpug 1,677 Posted January 9, 2007 (edited) huzzer, you confused the matter by stating that you're going to use a Motronic loom, so to some it may sound like you already have one! ECU you use all depends on what you can source loom wise, and vice versa. Edited January 9, 2007 by welshpug Share this post Link to post Share on other sites
huzzer 0 Posted January 9, 2007 Sorry for confusing everybody! What I meant was, I wont be using 8v management. Ah! So it doesnt matter which ECU and loom I get as long as they are both compatible? Share this post Link to post Share on other sites
welshpug 1,677 Posted January 9, 2007 yes!!! so you can use motronic from a ZX, 405, BX, megasquirt, KMS etc etc Share this post Link to post Share on other sites
huzzer 0 Posted January 9, 2007 Great. Thanks for clearing that up welshpug! Are they different between alloy and iron block? Share this post Link to post Share on other sites
welshpug 1,677 Posted January 9, 2007 alloy runs an AFM (2 row I believe but not 100% on that, later cars used an AFM and 3 row) iron block runs map sensor and 3 row, if you have the choice i'd go for the iron block ecu as it'll respond to tuning better and have less restriction in the intake tract, though you might need the map adjusted. it does allow coilpacks to be used, which IMO is much better. Share this post Link to post Share on other sites
Baz 421 Posted January 9, 2007 In that case, makes it a bit more difficult, especially if you're intending to use the chopped loom!! I still have the 3row setup for sale yes. Share this post Link to post Share on other sites
